10-09-2011, 11:50 AM | #1 |
CDI 2006 Zongshen 200gy
I just found this site, but before I did, I had a starting problem that for me traced back to the CDI. I bought a CDI for the TW, but as many of you know, and I found out the wiring is not the same. The bike starts and runs, but won't shut down conventionally. I'm going to attempt to get the CDI for Zong, but in the meantime I was going to put in a switch to shut down the lead that goes to the coil. Is there a better way?
I also read here that this could all stem from the magneto/stator. I've read several threads here now, but am interested in the collective opinions and experience on this site. Any ideas on which route I should take? |
10-10-2011, 02:55 AM | #2 | |
Re: CDI 2006 Zongshen 200gy
If possible, I would return the Yamaha CDI unit, since it costs about 4 times as much as the Zongshen CDI unit. If you can't return the Yamaha CDI unit, try selling it to the members of the TW200 forum. I encourage you to buy two Zongshen, CDI units from Zongshen America, so you will have a spare CDI unit handy. The spare CDI unit greatly facilitates troubleshooting the electrical system. Indeed, the Zongshen stator is wired differently than the Yamaha stator, so the two CDI units are not compatible. Also, I believe the Zongshen kill switch grounds the output from the Zongshen CDI unit. Can you stop your bike by turning off the ignition switch? Spud
10-10-2011, 08:54 AM | #3 |
I only yesterday wrote to the Zong USA people, so I am waiting to here back.
The bike runs on with both the kill switch and ignition shut down. Like I said, I was going to figure a way to shut down the bike by switching off the lead to the coil. I'm also trying to find a late model TW wiring diagram to compare the wiring. I have not ordered parts through the Zong folks yet. Is it as difficult as "people" say? Will using the TW CDI damage the bike? |
10-10-2011, 11:37 AM | #4 |
I don't know about the zong cdi, but on the scooter ones it is just one pin that is grounded when a kill switch or ignition switch is used.
On one of the scooters this wire to this pin was loose an it would not shut off either. I simply had to push it back into position. In other words. Check all the connections between the switches on the CDI. Make sure that the wires going into the connectors are seated properly. I would start at the CDI itself. |
10-10-2011, 11:58 AM | #5 |
I agree. I think that all CDI's have a terminal that is grounded out to kill the engine. The trick will be to figure out which one. You're breaking new ground here, greggu.
10-10-2011, 06:12 PM | #6 | |
In my experience, Zongshen parts are usually in stock in the Miami warehouse, at very reasonable prices. However, you need to exercise some patience, and persistence, to get your parts order filled. Keep contacting Zongshen America, and you will get the parts you need. Spud
10-10-2011, 09:37 PM | #7 |
Thank you
I currently have my kill switch wired to shut off the spark. Once I get the real CDI, I'll set it back to stock. I also noticed that my aftermarket tach was not working with the TW spark lead. I disconnected it until I get the right CDI.
Thanks for all the advice, This will be my #1 source for information. |
10-10-2011, 10:25 PM | #8 | |
Re: Thank you
http://chinariders.net/modules.php?n...ewtopic&t=8673 Spud
11-20-2016, 05:15 PM | #9 |
2006 qlink xranger 200
sorry I am new here jus picked up a 2006 x ranger 200 for $120 the wiring is butchered cdi an plug are gone is there anyway I can make a 5 pin cdi work
11-21-2016, 10:14 AM | #10 |
The Q Link X Ranger 200 actually looks like a Zongshen Sierra. If Spud doesn't come along shortly, please feel free to go over all of the pinned threads on Spud's Zong Sierra or just hit the search feature for the Sierra. Spud's a wealth of information when it comes to this bike.....so you found the right place! Welcome!
