Thread Tools Display Modes
Old 11-23-2011, 09:06 PM   #1
Honda 160cc Vertical Shaft Engine questions.
I changed the oil in my power washer today. I could find no drain plug. I removed the filler/dipstick and tipped the unit on its side over the collection bucket. Is there a better way?
Also, do I check the oil with the dipstick screwed in or not?
Thanks, hope someone knows. :wink:
Old 11-23-2011, 10:12 PM   #2
I don't know about the drain plug, but any Honda I ever owned said to check the oil with the dipstick resting on the case, not screwed in
Old 11-23-2011, 10:48 PM   #3
Thanks, you're right. I found a downloadable manual. It's for a horizontal shaft but I'm sure this is the same.
As far as the plug goes it would be nice to know but I can always tip it on its side and use the filler hole to drain it.
Truth be told that's how I drain all my dirtbikes! Faster and sometimes neater than the drain plug on the side or bottom. :wink:
Old 11-23-2011, 10:51 PM   #4
You know, come to think of it I think my lawnmower with a Honda engine says to tip it to drain it as well. Not 100% positive but I recall reading that in the manual.
Old 11-23-2011, 11:33 PM   #5
I found the plug.
No way to get to it withiut removing the motor!
Old 11-24-2011, 12:25 AM   #6
My old Honda mower requires that it be tipped over to drain the oil. There's no drain plug, because there's no room for one. It has a clutch system that allows the engine to run without the blade spinning. Once you pull the lever, the blade engages. It's very busy under there.
Old 11-24-2011, 10:00 PM   #7
katoranger's Avatar
I use a turkey baster with about 8" of fuel line stuck to the end. Just suck the oil out an into a container.
Typically the plugs are on the bottom and not accessible like you found.
