Old 06-08-2007, 07:01 AM   #1
uncle_jo3   uncle_jo3 is offline
my 520 conversion is done
cb200 rear sprocket, trx 200 front sprocket and a suszuki chain 72is mph thanks
Old 06-08-2007, 02:34 PM   #2
mdsuave13   mdsuave13 is offline
Send a message via AIM to mdsuave13 Send a message via Yahoo to mdsuave13
What Sprocket combo did you happen to go with? What are your impressions of the gearing? Do you have enough low end power, how is your top end? Etc... Thanks.
My name is Justin, my friends call me Stix.
2008 Kawasaki KLR650 Candy Lime Green
______________________________
I am the official China bike registration Guru For the State of Maryland..... HA.
Old 06-08-2007, 04:25 PM   #3
Is your speed due to the 520 conversion, or the size of your new sprockets? Mine came with 15/46 sprockets, 428 chain, and the bike is a 150cc. I asked about a 520 conversion at my local bike shop. The mechanic said it's cheaper to keep it 428, but get a better chain. I've waited a month to get my 17 tooth ordered, and still don't have it. They are backed up, but I've waited too long :evil: I think the 17/428 is the same size as the 14/520, and rotates at the same speed. I don't want to change my rear sprocket if I don't have to. Is there a reason I should change to 520? My bike is smaller and I don't weigh much. If I'm going to do it, I'd like to do it all at once, right, the first time. The bike shop did give me 4 free licence plate lightbulbs today.
Old 06-09-2007, 03:26 PM   #4
jeffhei   jeffhei is offline
I'm about ready to do the 520 conversion myself. Unclejo3 let us know which sprocket sizes you used, and how much did it cost for everything. Speed and rpms would be nice also.
2006 Lifan LF200GY-5
Old 06-09-2007, 06:09 PM   #5
SamM   SamM is offline
I'm also doing a 520 conversion. I hope to have mine done tonight. Getting ready to eat dinner now, so I should have pictures of it along with my new XR200R shock install later. My sprockets were purchased from Bruce at Endless Journey Cycles in Ohio. The sprockets are 11T front and 35T rear with a 520 D.I.D. chain. I was concerned about using a master link chain but I was assured it was fine on this type of motorcycle.
I have $135 in my conversion but this also includes a new Uni-filter aircleaner.
2013 Jeep Wrangler Sahara MOAB
2005 BMW E53 X5
2011 Schutt Industries LTT-HC LQG trailer
2017 Coleman CT200U
1978 Yamaha SR500E
1979 Yamaha XS650 Special II
Old 06-09-2007, 07:00 PM   #6
ob1   ob1 is offline
You will find your chain stretch and subsequent sprocket wear will all but disappear when you make your 520 conversion.
About a year ago, I finished the XR/Lifan 200, running 520 o-ring chain. 1 enduro season later with my lightweight daughter on board, and many hours of riding it myself, and I havent had to adjust the chain yet. It may be due for a little tweak, but far from actually needing the adjustment.
The Lifan makes plenty of power for "fat guy fun" and scoots along well with a lightweight rider, but not enough to challenge a 520 chain.
There is a reason Honda spec'd 520 chain on the XR200!
Old 06-09-2007, 07:54 PM   #7
Now that I have both of our bikes engines firmly mounted in I wonder how much of a problem the chain will be.We, like many others, went thru a few chain adjustments but it seemed more do to the engine moving.
I noticed most of our chain slack was from the engine moving around and being pulled from the torque of the chain on it but now I feel the chain is really going to be (sorry ) the weakest link.
I may do the 520 conversion in the future.
Old 06-09-2007, 11:10 PM   #8
Here is my 520 chain conversion, all finished up! I may need to remove another link.
2005 BMW E53 X5
2017 Coleman CT200U
1978 Yamaha SR500E
Old 06-11-2007, 12:48 AM   #9
Question:
On a 150cc, with 125LB rider, riding street only. Would a 428 D.I.D. chain stretch much?
Old 06-11-2007, 01:27 AM   #10
jkomp316   jkomp316 is offline
Send a message via AIM to jkomp316
well, im 145lbs on a 200cc, street and some dirt... my stock 428 on my Lifan has been fine. when im riding 2up and grabbing handfulls of 1rst gear, then i worry... how much is a cheap 428 chain? like $10? a tank of gas?
Old 06-11-2007, 01:52 AM   #11
I mean a decent 428, not stock. Would a good 428 chain be ok? Or would it stretch alot too?
Old 06-11-2007, 06:39 AM   #12
well i have a whole 35$ at most into my conversion. most my parts were from old (70-80's) bikes.front sprocket(if countershaft) trx200, find it on ebay. rear sprocket, local cycle salvage, chain off a suszuki i had. my gearing is 13 front 34 rear my takoff is done for. but i get around 70-73 mph, my rpms are way down, heck i cant even here the engine cause i aint screamin wfo just to keep up with traffic. im using a 30+ year old chain and i am over 250lb so it is stretchin alittle bit(my 428 stretched alot) i think im goin to get alittle more top speed when i get a new rear tire. i think a 520 chian and sprockets offer better gearin options. each gear takes alittle longer but its fine with me. gas mileage has improved i think. as for the side cover mod that is on one of these sticky post my side cover broke off so it still fit just fine in the space allowed. before i got my 13t front i was running an 11 front with the still same 34 rear and i even then noticed that i still had good take off and decent top speed(65) now 15f/34r(70-72) and stock 15f/50r(60-63) so..... for 35 bucks and about an hour combine to do everything i think it was worth it
13t front sprocket-16$ with shipping off ebay(trx200)
11t front sprocket -5$ from local cycle salvage yard
34t rear sprocket- 5$ from local cycle salvage yard
520 unkown link chain-free(well the bike cost me 50$) from my back yard
misc stuff- around 10$
Old 06-11-2007, 07:09 AM   #13
ob1   ob1 is offline
Chain stretch and sprocket wear come from a number of factors; chain quality, bike weight, rider weight, riding surface. Then you can add gear ratio and riding style; hard on the throttle, downshifting as a brake, etc, or not.
My bikes see no roads, except in the course of an enduro race, and are ridden hard. I want them bulletproof. One less thing to go wrong and ruin a ride/race.
For me the 520 was a no-brainer. When I installed the Lifan motor, I already had the 520 chain and 520 rear, all I had to do was get a front sprocket {aftermarket, for a CRF230}.
One of the quickest ways to stretch your chain is to have it too tight.
Old 06-11-2007, 07:16 AM   #14
cycleway4   cycleway4 is offline
I switched out my stock chain, for a premium 428 chain before ever riding my bike......still havent had to adjust it yet.......about 500 miles.
In most cases, I believe a premium [428] chain is all these bikes need.
I have the stock sprockets.....17/46
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 06-11-2007, 12:26 PM   #15
how many links does a stock GY-5 428 chain have?
