03-22-2013, 01:01 PM | #1 |
turn signal wiring issues
2004 panterra 125cc
i get no lights at all to the blinkers. they dont blink or come on at all. i have a 550 dot flasher. maybe it's the wrong one i have no clue because i can't find jack on this bike lol. there was a connection under the seat with a grey and a black wire, which i assumed was for the flasher. it plugs right up. however my flasher has 3 prongs. p, l, x. i have the signal wires connected in the front directly via spliced into the main harness orange/green, blue/green. the rear signal wires are each plugged into connectors under the seat via same color connections in the harness orange/green, blue/green. i have tested the lights and the bulbs do light. so what's the deal with the signals not working? any help here? do i need another relay, another fuse, more wires ughhh lol i want to be safe when i turn! cant believe they aren't required here. |
03-24-2013, 01:59 AM | #2 |
Assuming the two prongs on your flasher are properly oriented with the plug, you will also need to connect the third prong to the frame to ground it. The 3-prong connectors will not work unless the third prong is connected to an electrical ground.
03-24-2013, 05:59 PM | #3 |
thanks, Spud. always very helpful.
03-25-2013, 01:03 AM | #4 |
i have seen a lot about 2 terminal flashers. maybe i got a 3 when i only needed two?
03-25-2013, 01:07 AM | #5 | |
03-25-2013, 09:17 AM | #6 |
very true. i have extra wire as well. i have a friend using his charger to see if any life can be pumped back into my battery but i will be able to check this at some point. stay tuned
