questions and concerns
so here are my questions
1. how is the power going up hills and things? I live in an area where there are a lot of hills, I would hate having drivers honk at me as I bogged up a hill 2. I weigh 160, would getting a smaller bike (weight, not cc) help me go faster? I know these things dont have much power to begin with 3. I always here about mount bolts coming off, are they breaking or just getting unscrewed? 4. the bikes I am looking at have rear drum brakes, good or bad? I cant think of anymore at the moment. Thanks for your time guys!! |
1) It really depends on the hill... I live in BC, lots of hills here... But I rode it from abbotsford to spences bridge on the highway (about 3 hour ride into the mountains from the valley), and I did slow down a bit on the hills, I couldn't pass empty trucks, but I think I was keeping pace with the loaded ones. But this is on the highway, ~100km/h, on normal roads you should be fine. Or off road you should be fine also, you just may have to gear down.
2)Obviously the lighter it would be the faster, but I don't think these bikes are too heavy to begin with, also I weigh quite a bit more then you, and I had my bike loaded up with gear, and rode on the highway (I even passed some cars in the fast lane). It is of course not a racing machine though. 3)Usually they are just getting unscrewed, loctite is your friend. Some do break sometimes, my rear top motor mount has broken 3 times, but I never replaced it properly, I used ready-rod. The original bolt wasnt great. I think the motor mounts on these arent the best. Other things I have heard break is the rear tailight aseembly, but im not sure which bike that was on. 4)I don't really know either way, they should work fine... |
I live on top of a mountain. It's about 2 1/2 miles at a steady incline up with stop lights along the way. I'm around 160 lbs with a 200cc bike and have no problems getting the bike up in gear and staying with traffic even after coming to a stop on the way up.(the speed limit on my street is 55 mph). I've heard of people breaking bolts but mostly it's the bigger guys and a lot of them are riding off road fairly hard. I've kept mine mainly to the street and dirt roads and haven't had a single problem with broken bolts. Bolts do get loose, so once a week I check all the bolts, loctite as necessary, and perform normal maintenance (check and lube chain, check spark plugs, check wiring, check fluids, ... etc). I haven't heard anything bad about the new drum brakes but can't really comment because my bike has disc brakes. These bikes aren't speed machines but at 160 I'm able to get just under 70 mph on the highway and hold that speed without a problem. Hope this helps
I dont plan on racing these things, but I dont want to make people mad/get smushed by a big rig.
If You ride any bike, You stand a good chance of getting smashed by one cage or another..These are good trail bikes and town cruisers IMHO..Mine will pull uphill and get to top speed while doing it..They are not bad bikes for the money. You just need to keep an eye on things..Just like You should do with any vehicle.
*EDIT* This made me think, Every video of these bikes including mine are done on backroads or with no traffic or in the dirt. Maybe somone can post a vid of them in town/city traffic going to work or something..I can't because mine is not legal to ride on the street..But it might help of these questions come up again.
Me and the wife ride ours around town the most and they are good enough for that with no problem just stay off the expressways.
We have ridden them offroad and while I do fine with mine my wife just can not ride hers in the sand and I must confess they are a handfull in the sand.(but I like it) I did manage to ride hers up a rather large sand hill several times a couple of weekends ago and they will do some decent offroading for what they are. You will have no problem keeping up, moving with traffic even if it's a bit hilly (they are 5 speeds you know- ![]() The engine mounts are a very weak spot but can be taken care of relatively easy so thats not really a problem. Drum brakes should work fine and in fact may be better than the disc brakes since the disc brakes tend to want to lock up somewhat randomly until adjusted just right. Drum brakes only fail badly when you go thru deep water and basically they dont work for a little while until some of that water gets out of there. (I'm talking a deep river crossing with drum brakes submerged then up on the throttle into a quick stop type of thing) Washing the bike or going thru a puddle wont effect drum brakes at all. ![]() |
#7 | |
We cant go on the expressways around here the speed limit is 70mph(minimum is 55mph) so everyone is going 75-90+mph and there are far to many people on the expressways around home.
Plus the bikes top out at around 70mph or so. They are really fun up north where it is a bit more layed back. |
Oh ok, I didn't realize the limit was that high, all our highways around here are 100km/h, there are some at 110km/h on the island, but I don't know where else. That would be pushing it.
#10 |
how about steps, can these bikes go about some steps? (about 6-8 steps)
#11 |
I can pull some steep hills at 50plus mph that I usually need to downshift to 3rd on in my car. (its an escort
![]() The 200cc has enough power for roads less 60mph safely. I don't ride on the expressways either. Allen
#12 |
I assume it could do it... (steps), we have step on the patio, just one, and ive gone up and down it
#13 | |
I only have a 150cc but I was on 2- 400 series highways today. Not far 10k or so. I have an older camara that takes good mpgs. Also, I have 2 - 128 meg drives that I don't need anymore since I bought the 1gig. I've been thinking about mounting the camara and taking a movie with sound. I'll do it. But I have no where to up load it to and it would take for ever. Dial up. I'd save a copy for myself, but I'd mail it to anyone who wanted to see it, or post it for me somehow. N2r. :idea: Around town or highway or both? |
#14 |
Tough with dial up, I use my Myspace page....I have a You tube account but have never posted on it. I searched You tube again tonight and cannot find one street video...Kick azz of ya to step up to the plate N2R. 8)
Not sure on how to get it posted though. One thing I was going to do on my camera was glue a fuzzy off of an old headphone set I have to block the wind from the Mic hole on the cam...Thought it would help clear up the noise issues.
#15 | |
