Old 07-24-2007, 09:12 PM   #1
ratboy   ratboy is offline
Viva 110cc ATV wont start
My friend purchased a Viva 110 ATV for his kids. They rode it for a few weeks and now it wont start. When you hit the starter button the startor relay makes a noise but that is it. We put the battery on a trickel charger thinking that the battery might be low but that did not seem to do any good. I also swaped out the starter relay with one from a honda cb550 that looked almost identical and I knew was good and it just made a louder clicking noise. Any thoughts on what to check next.
:evil:
Old 07-25-2007, 02:46 AM   #2
liverchip   liverchip is offline
Send a message via MSN to liverchip
Might be a bad battery. You could jump it to verify. Might want to check the ground as well.
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 07-25-2007, 11:47 AM   #3
AZ200cc   AZ200cc is offline
The stock batteries in these are junk, Have the battery tested and it will probably have a bad cell.
Old 07-25-2007, 03:24 PM   #4
NewEnglandTrails   NewEnglandTrails is offline
ratboy,
Have you checked to see if the kill switch was reset and or is functioning properly? Tapped the solenoid?
Sounds like a bad battery or ground.. Maybe try a battery charger with the boost mode and see if you get enough power to turn it over..
NET
2006 HIBIRD QH200-st atv, 2005 Kinroad 200GY-01, 2006 Roketa DB-05, 1980 Kawasaki KZ440 LTD
Old 07-25-2007, 11:38 PM   #5
I'll pull one of the batteries out my honda and give it a try. The battery that is in there was put in with zip ties instead of bolts so I bet it was getting bounced around pretty good. I'll let you know what happens with a new battery.
Old 07-30-2007, 09:49 PM   #6
hooked it up to a battery from my honda cb750 and it started right up - thanks
Old 07-31-2007, 04:25 PM   #7
ratboy,
Psyched to hear you got it started. You can always get a $23 battery from walmart to replace the stock battery... I've had to replace two out of three batteries... from my MIC (made in China) products.
Also of note... if you ever have the occasion to charge these batteries make sure you use a charger capable of 2 amps... anything higher will shorten the life of the battery..
NET
Old 07-31-2007, 11:10 PM   #8
Almost always something real simple with these, Glad to hear You got it running.
Old 08-15-2007, 02:47 PM   #9
molypod   molypod is offline
I am in the same boat now except the battery is good..
I thought it was a battery problem but I switched batteries with my GY and the battery started the GY just fine and my good Battery from the GY won't start the ATV.
when you push the start button it just "clicks" near the relay and won't turn over. Sounds like when you have a bad solenoid in a car circuit.
Old 08-15-2007, 04:58 PM   #10
First thing I would check is the ground.
Tusk bar risers
--mods---
15/40 sprockets
UNI Pod Filter
FMF Powercore pipe
Uni Pod Filter
Old 08-15-2007, 10:14 PM   #11
After a couple frustrating hours I took it back to the dealer who found that the starter was gone.. ( it was full of moisture) He put a new one in and voila! all is good. thanks to the warranty all free of charge.
Old 08-27-2007, 05:17 PM   #12
pedez2000   pedez2000 is offline
we just started this if you need parts we are working on it but if you need something just email us http://sunlparts.net/ http://roketaparts.net/
http://sunl-parts.com/
Old 04-19-2008, 09:14 AM   #13
DesertDog   DesertDog is offline
Re: Viva 110cc ATV wont start
:evil:
hey rat,
you've almost had that 110cc a yr now how'z it runnin for you,
i sell the viva 110's
give me some feed back, so far my customers are happy,
DesertDog
DesertDog
