need balance shaft cush gear for Lifan 200
Does anyone have a balance shaft cush gear for the Lifan 200 they would be willing to part with? Last time I had the side cover off I noticed it had a little play. Not an immediate problem but over the long run the springs break down.
For those not familiar, cush gears are seen mostly as part of the clutch basket. They have several springs inside that allow some movement between the gear ring on the outside and the driven splines on the inside and are held together with riveted steel plates. The balance shaft models use a smaller one to drive the balance shaft. BTW the nut that holds the gear to the balance shaft is a left hand thread. |
