Old 11-28-2014, 11:38 PM   #1
N3xT s3Qill   N3xT s3Qill is offline
Head Scratching honda cbr cdi on suzuki.
Theres a cheap suzuki gsf 400 bare motor I wanted to buy and throw my elecs and carbs off a honda cbr 400(rod bearings knocking)on to it I know the carbs will be ok its the cdi im not sure of.
The suzukis stroke is 40.5mm and the cbr is 42mm so im thinking it would just be a little retarded on timing the wirings the same 2 pins need to be swapped over they both have around the same output 58hp 13.500rpm-14000.
Old 11-29-2014, 07:09 AM   #2
humanbeing's Avatar
http://item.taobao.com/item.htm?id=4633691081 OR used CDI
Old 11-29-2014, 04:36 PM   #3
Originally Posted by humanbeing View Post
I want to know if i can use the honda stuff just because its all here instead of waiting for a order from overseas theres some here in new zealand but theyre around $200 which is how much the motor is cheers anyway.
Old 11-29-2014, 05:17 PM   #4
humanbeing's Avatar
Compare tabs (tells when to fire) btw 2 flywheel. Similar pattern/ length = compatible
