Old 10-19-2015, 09:35 AM   #1
keithmaine's Avatar
Stock wheel and tire options
I know the USA rear is 17 and the front 18, but from what I read the tire size ratio in the spec sheet is not what comes on the bike. So with that has anyone done a list that specs out all the tires that will fit the standard as shipped wheels?
Old 10-19-2015, 09:59 AM   #2
Here are links to some threads you might enjoy.
http://www.chinariders.net/showthread.php?t=14566
http://www.chinariders.net/showthread.php?t=5402
http://www.chinariders.net/showthread.php?t=14652
Old 10-19-2015, 10:00 AM   #3
keithmaine's Avatar
Thanks spudrider I will check them out
Old 10-19-2015, 10:11 AM   #4
You're welcome.
Since you are a TW200 owner, you are well familiar with many tire options for the 18-inch front wheel. However, since the RX3 is more street oriented than the TW200, I like front tires which will perform well at high speeds on pavement, in addition to performing well on gravel and dirt roads.
Old 10-19-2015, 10:20 AM   #5
keithmaine's Avatar
You're welcome.
You are the man,
I do know how I missed the links above I guess I was not awake yet well not enough coffee any way.
Old 10-19-2015, 10:23 AM   #6
Originally Posted by keithmaine View Post
You are the man,
No problem, Keith. A lot of forums will scold people to use the search function. We don't do that here. We are happy to help whenever we can.
Old 10-19-2015, 10:30 AM   #7
keithmaine's Avatar
go ahead slap me it is not like there thousands of post yet, I should have been able to see that this morning.
But I do love the attitude here
Old 10-19-2015, 03:14 PM   #8
We try hard to set ourselves apart from the typical forums. Any flaming that takes place here is good natured, and usually only after a friendship is established.
Old 10-19-2015, 03:58 PM   #9
If someone is rude here, we give them a little slack. If they are consistently rude, we call them out. We don't want to descend to the typically rude level of most forums. If we did, I wouldn't enjoy being here as much as I do.
