Old 03-16-2016, 10:08 AM   #1
mjstef   mjstef is offline
Who is interested in a Hawk OEM Tach Speedo cluster?
After about 2 weeks of back and forth with a manufacturer in China it looks like i will have a prototype replacement cluster with a tach to test shortly. This will have a wired sending unit from the wheel VS the speedo cable. I have another thread going on this but figured i would start a new one for interested parties. If the prototype works properly i will place an order for multiple units. I need an idea on how much interest their is for these. It looks as if they will come in at about $50-$60 shipped depending on the # i order. Post in this thread if your interested and i will fully review when i get the prototype in hand.
Old 03-16-2016, 10:30 AM   #2
mq1991   mq1991 is offline
Hell if its accurate MPH wise count me in. What will all be compatible with it? (Fuel gauge, gear indicator, etc)
Old 03-16-2016, 11:04 AM   #3
popeicus86   popeicus86 is offline
that looks beautiful and yea i'm with mq will the fuel gague, speedo, and gear indicator work.
Old 03-16-2016, 11:12 AM   #4
Likely NOT a gear indicator as that would take work inside the trans case but the neutral light will be there as well as high beam, turns, fuel gauge and trip odometer.
Old 03-16-2016, 11:22 AM   #5
fishtime9   fishtime9 is offline
I would definitely buy one of these, please add me to your list!
Old 03-16-2016, 11:47 AM   #6
Ron B   Ron B is offline
Ron B's Avatar
at that price ill take one also.
Old 03-16-2016, 12:14 PM   #7
Ichrisbot   Ichrisbot is offline
I'd get one too.
Old 03-16-2016, 12:33 PM   #8
kohburn   kohburn is offline
kohburn's Avatar
in for 1
the gear indicators don't use anything but the measured speed and rpm to estimate your gear (that is the programming bit, it needs to know the gear ratios essentially) combined with the neutral switch to know when its in neutral. nothing internal to the transmission.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 03-16-2016, 01:35 PM   #9
Originally Posted by kohburn View Post
in for 1
Hmmm, I'll have to ask about that then........
Old 03-16-2016, 02:15 PM   #10
kohburn's Avatar
there are aftermarket ones that use hall effect switches and a magnet on the shift lever to sense when you shift up or down. but that is so universal that I doubt this one uses that system. more likely it uses the calculation method using speed and tach.
- 2016 CSC TT250
Old 03-16-2016, 07:19 PM   #11
paulesmann   paulesmann is offline
paulesmann's Avatar
I'd buy one if they work like butter for the Hawk
Paul Mann
2015 Haosen Hawk
1989 Kawasaki EX500
1991 Suzuki DR350
Old 03-16-2016, 07:45 PM   #12
closedquestion   closedquestion is offline
I'd be down!
Old 03-16-2016, 09:00 PM   #13
I'll keep y'all informed. Getting close to the time of night i get e-mails from China so hopefully it will be good news tonight....
Old 03-16-2016, 09:38 PM   #14
humanbeing's Avatar
Gear indicator is found in most stock vertical chonda engine.
Most "变速鼓" https://huabmp.taobao.com/search.htm...E4%CB%D9%B9%C4 had that Brass tab / Some model lacks "档显" (the wiring) https://huabmp.taobao.com/search.htm...d=%B5%B5%CF%D4 ONLY
Old 03-16-2016, 10:14 PM   #15
pistolclass's Avatar
I'm interested.
