Old 03-26-2016, 07:01 PM   #1
fishtime9   fishtime9 is offline
Hawk Carburetor Problem
I just installed the mikuni carburetor with a 115 main jet and 30 slow jet. I am amazed of the power and torque the bike has now, as well as it cruises at around 60 m/ph. However, it sputers constantly and it loses power when holding it at one constant speed setting. Could this be because of my pilot screw position? I can also upload a video if needed for further examination about this problem.
Old 03-26-2016, 07:39 PM   #2
TXDSRIDER   TXDSRIDER is offline
TXDSRIDER's Avatar
Does it do it no matter where in the Rev range you hold it.
Brandon
2014 Hawk 250
Firehawk minibike
Previous bikes~
1995 Yamaha YZ125
1998 Yamaha YZ250
1981 Yamaha YZ465
1987 Honda TRX 250R X2 one stock one modified
2002 Buell Blast
2001 Buell X1 Lightning
2000 Kawasaki ZR7
Old 03-26-2016, 08:15 PM   #3
Wolftrax   Wolftrax is offline
Wolftrax's Avatar
Air leak, loose battery connection.
Mark
2015 Haosen Hawk 250
2014 CRF250L
2014 CB500X Rally Raid
Old 03-26-2016, 08:29 PM   #4
newrider93   newrider93 is offline
newrider93's Avatar
Sounds like an air leak. Check the air vent from the box to carb. The silicon they used on mine was not heat resistant and gave away. I bought some automotive sealer at the local auto store and sealed it up.
Old 03-26-2016, 10:20 PM   #5
I checked my air box. However, it does not seem to have a air leak. Is there anything else that could be causing this, and it only occurs when holding the speed at a steady position. Basically, it sputters at that specific type of point and seems like its loosing power. I can upload a video tomorrow evening of it, if that helps?
Old 03-26-2016, 10:46 PM   #6
newrider93's Avatar
What's the spark plug look like? Did you replace it with an Ngk?
Old 03-27-2016, 08:41 AM   #7
Ron B   Ron B is offline
Ron B's Avatar
when I got my carb I ran my mixture screw in and counted, it came a little over 4 turns out. I set it a tad over 1 and a half out
Old 03-27-2016, 10:38 AM   #8
Spark plug as mentioned? Get an NGK D8EA or the iridium equivalent, DR8EIX.
What position is your slide clip in? Go one up from the bottom slot (4th down).
Mixture screw should be about 1 and 3/4 turns out.
Have you adjusted the valves?
I'm wondering about all these Hawks and Storms that are doing all the intake mods and not doing anything with the exhaust, regarding removing the cat or changing the muffler.
Old 03-27-2016, 06:45 PM   #9
chuck   chuck is offline
I did the carb upgrade and installed a Pro circuit T4 full exhaust and the bike feel like it gained a few horses.
Old 03-27-2016, 09:42 PM   #10
I will most likely take the carburetor next weekend off again and mess with the pilot screw. However, I personally think that the jet setup in general is not made for this engine.
Old 03-28-2016, 12:37 AM   #11
mq1991   mq1991 is offline
I did the upgrade, it took me a few tries to get the jetting right, but now it works awesome. Mine sputtered bad at high rpm when I was running it too rich. I went from 120 to 125, and it got worse, then I went to 115 and it cleared up.
Play around with your jetting, it takes awhile and can be frustrating but its worth it.
Old 03-28-2016, 05:44 PM   #12
I am currently running a 115 main jet, as well as 30 slow jet.
Old 03-28-2016, 07:21 PM   #13
Sport Rider's Avatar
Is your pilot screw at 1.5 turns out? Also, what do you have your needle at? Mine is in the second slot from the top. I had a guy with some carb experience ride it this weekend. He said it smelled a little rich but said it rode pretty well. He said no more changes and just to enjoy it.
Old 03-28-2016, 07:52 PM   #14
I think the smell comes from the cheap ass seal from that gas cap. I made mine tighter by stretching the inner Springs in the cap which helped but she is still a bit gassy.
Old 03-28-2016, 10:12 PM   #15
zingshoen   zingshoen is offline
zingshoen's Avatar
could be rich on the idle jet, i found 25 / 115 better, but it shouldn t cause sputter.
i had severe sputter one time from blocked venturis on the air intake side, try running with the airfilter hose disconnected, just for testing.
1971 Garelli Gulp 50cc with open ports and 16 mm Bing Carbie + 1980 Honda XL 223 ZS + 2007 Zongshen LZX200G + DR400SM
