Old 06-04-2016, 06:23 PM   #1
DanKearney   DanKearney is offline
How much (If any) RX3 swing arm lateral movement.
Howdy All,
Had the bike up on the lift for chain maintenance today. While I was at it, I checked the swing arm for lateral movement by grasping the swing arm at the rear axle point and pulling/pushing while I held the bike steady.
I see ~1mm to 2mm of lateral movement at the end of the swing arm.
Should there be any lateral movement, or is there a tolerance?
Cheers,
Dan K.
Dan Kearney - Black Hawk, Colorado, USA
Dan's Motorcycle Blog - "Lost? I'm not lost. I'm just exploring. . ."
Old 06-04-2016, 08:03 PM   #2
Jay In Milpitas's Avatar
I can't say for certain, Dan, but since the swing arm bearings are needle rollers (which need an itsy bit of clearance) I would not be surprised if 1-2 mm of play is normal.
Have you pulled the arm to clean/inspect/grease the bearings?
Old 06-04-2016, 11:38 PM   #3
rjmorel   rjmorel is offline
rjmorel's Avatar
Dan, My RX3 swingarm will move up and down with about 1/8" free travel when on the center stand which is from slop in the suspension linkage. Left to right not to much if any at all. rj
Live Zong, and Prosper
Old 06-05-2016, 12:17 AM   #4
Thanks for the input guys.
Cheers,
Dan K.
