Old 06-06-2016, 10:50 AM   #1
aaronwes   aaronwes is offline
aaronwes's Avatar
Angry cfmoto 650nk
hey guys im new to riding on the road and i just bought a 2014 cfmoto 650nk anyway my speedo is going all sorts of crazy when i accelerate reading of speeds up to 150 or so while im only doing around 60kph
Old 06-06-2016, 11:34 AM   #2
i would think the speedo cable needs lubrication. try a little penetrating spray down the inside of the cable just under the speedo connection. i think what is happening is that the inner cable is catching , then twisting up, then finally releasing causing the indicator to increase. just a thought.
disregard this if it is a digital speedo
Old 06-06-2016, 11:57 AM   #3
dpl096   dpl096 is offline
dpl096's Avatar
Welcome aboard .... and good looking bike BB is right. Start with the cable and lube it, and all the others too, with some quality lubricant.
― Thomas Jefferson
Old 06-06-2016, 12:30 PM   #4
aaronwes's Avatar
yeah is digital
Old 06-06-2016, 01:18 PM   #5
kohburn   kohburn is offline
kohburn's Avatar
only when accelerating? not when cruising?
might need something to filter the power input into the display. voltage fluctuations and electronic noise could be messing with it.
a sparkplug/wire that is jumping to ground can also doe funny things to digital electronics.
- 2008 Kawasaki Versys
- 2016 CSC TT250
Old 06-06-2016, 01:52 PM   #6
Re-seat the connector. check for loose pins in the multiplug not making connection. grounds also play important role in electronics. check for bad wire harness too (ie damaged wires).
Old 06-06-2016, 02:25 PM   #7
kohburn's Avatar
definitely check the connectors (add some dielectric grease) and check the grounds.
if its happening at acceleration but not cruising then the movement of a connector bundle could be causing it.
- 2016 CSC TT250
Old 06-12-2016, 11:59 AM   #8
wheelbender6's Avatar
I wish CF moto sold that 650 in the US. I think they have even stopped selling scooters here.
650, cfmoto, cfmoto650nk
