Old 07-14-2016, 10:45 PM   #1
hertz9753's Avatar
Hawk turn signal alarm
Is there a link on how to disable the alarm? I turned the ignition switch on in my shop and the turn signal was on. My dog and I have trust issues now.
Old 07-14-2016, 10:48 PM   #2
w0ss   w0ss is offline
If you look at the bottom of the blinker module(under the seat) I believe you should see an opening at the bootm. If you stuff some paper towel in there it will muffle it. If you are ok with making a permanent change you can take it apart and clip the wires for the speaker. I was amazed at how tiny the speaker is yet it makes such a loud noise.
Hawk 250 with following performance mods: 17t, Mikuni with 110/25, Uni filter, Exhaust.
Old 07-15-2016, 12:05 AM   #3
hertz9753's Avatar
I found the flasher and unplugged it. No turn signals and no alarm now. The flasher box is sealed but does have some movement were the connections go into the box.
Old 07-15-2016, 12:13 AM   #4
mjstef   mjstef is offline
The cover will pop right off. Not sealed tight.....
Old 07-15-2016, 12:29 AM   #5
pcspecialist   pcspecialist is offline
I taped over the opening to quiet the alarm. It's good to have a reminder the signals are flashing.
Old 07-15-2016, 12:37 AM   #6
hertz9753's Avatar
I used a couple of small precision screwdrivers to pop the end of the box off. That speaker is tiny but it has a big bark.
Old 07-15-2016, 01:26 AM   #7
humanbeing's Avatar
SpudRider, pls include this topic in FAQ
Old thread: http://chinariders.net/showthread.php?t=16442
Old 07-15-2016, 01:29 AM   #8
hertz9753's Avatar
I snipped the wires and pushed on the speaker with my finger and it came loose. I don't need an alarm when I have four lights in front of me that I can see on the Hawk.
Old 07-15-2016, 11:51 AM   #9
Old thread: http://www.chinariders.net/showthread.php?t=16442
Done. Good idea, HB.
Old 06-12-2018, 11:33 PM   #10
Sf16   Sf16 is offline
What is the speaker for
Old 06-13-2018, 07:39 AM   #11
roundhouse   roundhouse is offline
roundhouse's Avatar
That was the first thing i did to my hawk. snip that wire!!!!!!!!
Old 06-13-2018, 11:14 AM   #12
It beeps in time with the signals, so you can hear that the signals need to be switched off.
Old 06-13-2018, 01:09 PM   #13
pistolclass's Avatar
I kinda like mine. It gets the attention of folks at stop light so I hoping it increases my chances of awareness that I'm there.
