07-28-2016, 10:52 AM | #2 |
Good news. The TT is "getting better" but is still hard to find when hot. I'm hoping as the miles and oil changes happen, it will get much easier.
07-28-2016, 10:54 AM | #3 |
everybike I have ever had ...
XR70 CR125R CR250R R6 all were hard to find neutral ... maybe this bike it worse but a trick i found was to tap the shifter instead of trying to go super easy |
07-29-2016, 09:15 AM | #4 |
My brother's is quite easier to get into neutral on his Hawk, but mine as it get's hot is almost impossible. It may make a huge difference with an oil change though. I'm gonna try to run some really good GN4 oil in it and see if it helps when I do the oil change.
07-29-2016, 01:20 PM | #5 |
after riding my hawk i get what your saying but try this .... when your in 2ed gear just tap the shifter down ... use your foot like a impack gun just tap and once you get used too it you will find N real easy
07-30-2016, 02:58 PM | #6 |
My speedometer quit working at 20 miles and the odometer followed at 30 miles, but at what I estimated to be 50 miles l changed the oil to conventional Valvoline 10w-40 4 stroke motorcycle oil, because I was not able to find neutral at all with the engine running and I figured it couldn't hurt to try.
The only way I could get it into neutral was with the engine off. I was getting false neutral indications too, which concerned me. I tried the light tap down from second. I tried everything. The oil change seems to have done the trick. I can actually find neutral relatively easily now. If I could get a working speedometer and odometer, I would be really satisfied with this bike.
2016 CSC TT250 |
07-30-2016, 03:24 PM | #7 |
I'm going to.
2016 CSC TT250 |
07-31-2016, 09:03 AM | #8 | |
The light tap approach that has been mentioned for finding neutral works well for me. |
07-31-2016, 11:06 AM | #9 |
Yeah, the only problem is the guy has to buy 100 up front and there may not be enough interest for him to fork out the cash.
2016 CSC TT250 |
07-31-2016, 11:49 AM | #10 | |
I'll get them ordered tonight. I think their is enough interest and as word gets out their will be more. The accurate speedo is a HUGE plus as well as the gear indicator and the low fuel light..... |
07-31-2016, 03:13 PM | #11 |
I was hoping you'd say that!
2016 CSC TT250 |
