11-11-2016, 03:18 PM | #1 |
Shifter Oil Leak - Hawk 250
I tried searching but I couldn't find the answer to this. Can anybody enlighten me on where to get a replacement o-ring?
11-11-2016, 03:41 PM | #2 |
I will bet you that every Hawk have that leak it just not everyone noticed it yet.After a nice run I touch the bottom of the engine and there is always a little bit of oil around the shifter.The good thing is it does stop when the engine cools down a bit.I'm not concerned because it's not enough to cause any problems.
11-11-2016, 06:16 PM | #4 | |
11-11-2016, 06:35 PM | #5 |
Ok, that is bad.
11-11-2016, 07:11 PM | #6 |
Mudflap has a pretty good answer to your problem.
11-12-2016, 05:33 AM | #7 |
Yup, it's a 5 minute job. Why put up with a leak?
07-03-2017, 03:47 PM | #9 |
Thanks for the follow up. Mine doesn't leak, but if it ever does at least I know which seal to get
Hawk 250 Mikuni carb 115 main. De-catted pipe. Air box mod. 15/42 sprockets. Digital instrument cluster, FMF end cap on muffler, handlebar toolbag, Custom foot pegs |
07-03-2017, 03:50 PM | #10 |
Yep, I already got it written down in my little book along with the Honda 17211-ZL8-023 air filter, ect.
07-03-2017, 04:41 PM | #11 |
Mine is leaking, I thought it was leaking from one of the case bolts, now I know where the leak comes from
Tags |
oil leak |
