11-12-2016, 07:37 PM | #1 |
Clutch diode
Where is the clutch diode located on the hawk? Neutral light comes on when I disengage the clutch. I believe the clutch diode is bad.
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-12-2016 at 09:06 PM. |
11-12-2016, 09:37 PM | #2 |
I would be looking for a problem switch not a diode.
11-12-2016, 09:47 PM | #3 |
It's not the switch. It's the diode. I just can't locate it.
11-13-2016, 08:25 AM | #4 |
Never heard of a clutch diode before ,can you tell us how you came to this conclusion ? .The only diodes common on a bike are in the rectifier and the turn signal circuit .The neutral light circuit typically consists of a switch and a bulb ,with the switch being located around the countershaft sprocket area of the bike .Often the wires get pinched under the engine cover .I can think of no reason to have a diode in the circuit unless the idiot light does multi functions .
11-13-2016, 08:44 AM | #5 | |
11-13-2016, 09:59 AM | #6 | |
11-13-2016, 10:13 AM | #7 | |
11-13-2016, 10:38 AM | #8 |
I went out this morning and traced it down. It was taped up in the harness under the tank. Mine plugged in but if you take the cap off it it had a diode in it that was burnt in two. I pulled a diode off an old motherboard i had laying around and solder it in. Everything is working. Thanks Merlin but beat you to it lol
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 11-14-2016 at 07:35 AM. |
11-14-2016, 04:17 PM | #9 |
Update
After I put everything back together I went out a took a little 78 mile ride and still working. I forgot to mention that the clutch diode had stop working after I had replace the sending unit on the gas tank. The one that came on the bike had stop working the 1st trip I had made with the bike. I may have smashed a wire or something in the process that may have shorted the diode. who knows? Good news is now I have a working fuel gauge and I'm not guessing if I have it in neutral or not before I release the clutch.
11-15-2016, 12:07 AM | #10 |
Thanks for the explanation. My Lifan has a diode and I wasn't sure what it was for, so I left it there. Glad I did.
11-15-2016, 08:11 AM | #11 |
Well the wiring diagram that's in the Hawk owners manual is useless. The diode is drawn in but not labeled. It's a good thing I know electronics and knew what the symbol meant. I have built and repaired many computers in my life time. I'm still waiting to hear back from RPS. I don't think they know where or what it is. lol
11-15-2016, 11:18 AM | #12 |
The diode on my bike is found in the harness behind the headlight, IIRC. I figured it had something to do with residual energy after shutting the bike off, but I never bothered to trace it. Like you, I pirated two diodes from an old PCB to enable the LED turn signal on my TW200, because I'm way too cheap to actually go buy some.
11-17-2016, 02:01 PM | #13 |
Update: APSCUSA has come through again. New Clutch diode has been sent out. I'll have a back up in case it happens again.
