05-08-2017, 03:19 PM | #1 |
plug still pure white
made it to my biggest main jet (125) doing plug chops along the way and it is still pure white like a new plug???? search for larger main or search for larger pilot???? did anyone find pilots for the shinwey carb on the hawks?
05-08-2017, 03:28 PM | #2 |
if 125 isn't big enough, something is funky with your carb.
05-08-2017, 03:37 PM | #3 |
???? 2 turns out on the bottom mixture screw, 2 washers under needle, airbox mod, exhaust mod. could just be the carb????
05-08-2017, 04:01 PM | #4 |
You may want to check the jet and make sure there's not something in it like a burr from the machining of the jet.
05-08-2017, 04:52 PM | #5 |
I would check the float height as well as the main jet. A too low float level will also result in a lean mixture...ARH
05-08-2017, 07:37 PM | #6 |
Yeah, this. I made a recent post about this. Might not be the case, but it is something easy to check for.
05-09-2017, 01:57 AM | #7 |
i looked thru the jet before i put it in and the 120 before it too so im off the check the float level tomorrow.
05-09-2017, 02:14 AM | #8 |
If anything you could always just order a new and return your broken one in the box for a refund?
