Old 05-20-2017, 05:16 PM   #1
leo in wv   leo in wv is offline
coil coil and recoil
i ordered a coil on ebay recently, the listing says up to 250cc, but they keep sending me coils that clearly say 50cc-125cc on the label.
everything else "seems" to check out ok. i even went so far as to completely rewire the entire bike, just in case i may have missed a ground or something...
it will start and run for a couple minutes, then die. after that it will crank until the battery goes down without ever hitting again. if i give it 30 minutes to cool down, it starts right up and we do the whole thing again. it was running great before this coil issue came up.
am i missing something? are these 50-125cc coils the same as the 200-250cc coils?
the ebay seller says they are "identical" to the 200-250cc coils... i'm not so sure...
Old 05-20-2017, 05:40 PM   #2
Bruce's   Bruce's is offline
Try sticking the cdi in the freezer for a half hour to see if it will run a little longer .I have run tiny weedwacker coils on 250 dirt bikes before ,don't know what coil you ordered but it might be fine .
Old 05-21-2017, 10:16 PM   #3
dpl096   dpl096 is offline
dpl096's Avatar
I've not tried the freezer test b4 but I've been told it helps to diagnose a coil failure....anxious to hear your results
― Thomas Jefferson
Old 05-22-2017, 08:34 AM   #4
bogieboy's Avatar
I would dare say that your coil is fine... I would be replacing the cdi box before the coilll lot more to go wrong with a cdi...
Old 05-22-2017, 06:18 PM   #5
i am willing to give it a shot. i looked at some cdi's en ebay, not sure about which one. what is the difference in the dc and ac cdi's?
