01-10-2018, 09:32 AM | #1 |
Probably a noob question, but how do you remove the seat on the Brozz?
There are no bolts for it and no levers that I can find. It seems like I should be able to pull the seat back, and off, but I can't. Does anyone know how to remove it?
01-10-2018, 09:42 AM | #2 |
I even found the holes where the bolts SHOULD be, (looking at the TT250 tutorials) but there is nothing in them, and nothing connected to the seat.
01-10-2018, 09:42 AM | #3 |
Not sure if it is like the Hawk. The Hawk has a bolt on each side of the seat. letsride could answer that question as he owned a Brozz.
01-10-2018, 09:56 AM | #4 |
Yeah, the frame has holes drilled out for those bolts, but it seems like the makers decided not to use them. I have a feeling that I just need to muscle it off, But I am weary - at least until I know for sure if the TT250 replacement seat will fit.
01-10-2018, 06:58 PM | #5 |
you have to remove the rear fender to get to the bolts that hold the seat on in the back
01-10-2018, 08:31 PM | #6 |
Yep what ^^ he said. Its the DUMBEST thing they did on that bike. Its not a big deal just more time consuming than it should be.
