Old 02-07-2008, 07:25 PM   #1
katoranger's Avatar
I think the rear master cylinder died.
I haven't ridden in about 3 weeks and I went out to start of the 2 and the rear brake was sticking. Cracked the bleeder and now I can't build any pressure. Resorvoir has plenty of fluid and was not low.
I think that the rear master may be done. I will have to see if I can vacuum bleed it but it may be time to see if I can do a honda conversion.
Allen
Old 02-07-2008, 10:09 PM   #2
I think that was part of the reason Lifan went back to the rear drums on the GY-5's.
I know that Jetmoto has the parts on their site. My Jetmoto, right before taking its final dump, had lost its rear brake after sitting for so long. I would have ordered the part, but the bike went bye bye
Old 02-08-2008, 07:42 AM   #3
ejcycles's Avatar
Allen
I have some new master cylinders in stock... I'll see if they will fit the Lifan.
Old 02-08-2008, 09:18 AM   #4
katoranger's Avatar
I was doing research a few months ago when I was having troubles with it before and it looked like a master from a honda cfr230 I think might fit.
They looked close in design.
Bruce, let me know what you got.
Allen
Old 02-09-2008, 11:20 AM   #5
katoranger's Avatar
This is the rear master on the GY2.
And this is one from a late model honda cbr600.
The mounting points on both are opposite of the resevoir line and the clevis on the plunger is similar.
Might be close enough for a swap.
Allen[/img]
Old 02-09-2008, 12:02 PM   #6
AZ200cc   AZ200cc is offline
Looks like the one my Maxfine had also, Probably a standard china part
Old 02-09-2008, 12:05 PM   #7
katoranger's Avatar
I am sure that most of the china bikes had a similar unit. I found that master on ebay and ask the seller to measure the mounting points for me.
I think most of the trouble being had with the rear brakes is caused by the master cylinder.
Allen
Old 02-11-2008, 08:42 AM   #8
Allen
Ours wasn't really a problem with the master cylinder, but rather the location in relation to the push rod for the the cylinder which was causing the brakes to not completly disengage.
Jason
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
Old 02-11-2008, 01:11 PM   #9
katoranger's Avatar
The master seems to have quit completely not. I have adjusted it out and that worked great for months. Now I either have some large air bubble in the line or the piston seal is gone giving me no pressure. I am going to try to vacuum bleed the system to see if the works.
I got a response back on the CBR master and the mounts are 1.75 inches apart. I will have to measure to see if that will fit.
Probably going to be my alternative if the bleeding don't work.
Allen
Old 02-12-2008, 05:43 PM   #10
katoranger's Avatar
I spent about an hour trying to bleed the system and I got nowhere. The master just won't build any pressure.
Anyonw have any suggestions?
Allen
Old 02-12-2008, 05:45 PM   #11
Is it leaking past the seal that You can tell?
Old 02-12-2008, 05:47 PM   #12
katoranger's Avatar
I think that is where the problem is. I some some air bubbles down there.
I believe I am going to try the cbr master and see if that works.
Allen
Old 02-12-2008, 06:12 PM   #13
Allen
Not being too familiar with brakes, but having the exact same thing happen to my Jetmoto, the cylinders seem to give up, and you might as well replace it. I had priced one for under $40 direct from Jetmoto, but if the CBR one fits, you should be in business.
Like I said a few posts up, I think this is why A. Lifan went back to a rear drum brake!
Old 02-12-2008, 06:15 PM   #14
katoranger's Avatar
I believe that is what happen. I can get a honda one for about $20 shipped off ebay.
Probably last forever on there too.
They are lots of them on ebay. They don't seem to sell quick and it is probably because they don't break.
Allen
Old 02-12-2008, 06:39 PM   #15
I've never torn one apart, I wonder if it just uses an O ring on the piston.....Coudl be a simple rebuild job.
