Old 09-24-2018, 01:31 PM   #1
itsnt4me   itsnt4me is offline
itsnt4me's Avatar
Cleaning The Cat
Seems that some folks say they didn't get much out of cutting the cat material out of their exhaust and that they got more benefit from drilling out holes in the muffler. I wanted to get some of the back pressure out of the engine but didn't way to go to all the trouble of cutting out the cat and rewelding if there wasn't much of a benefit but drilling holes out of the muffler canister would be a lot simpler. I got rid of my welding equipment because I have a pacemaker and can't be around welding so was curious what you guys think. Would like to keep the stock exhaust because I like the way it looks. And I am cheap.
Old 09-24-2018, 01:42 PM   #2
Gut the cat and bring it to a local muffler shop to weld it back. Probably get it done for about $20. That alone was a huge increase in performance on my Hawk. I'm still running the stock exhaust.
Old 09-24-2018, 02:58 PM   #3
itsnt4me's Avatar
Did you also drill out the muffler canister?
Old 09-24-2018, 03:01 PM   #4
Yes, That help a little more but not as much as gutting the cat. You will also need to up the main jet to a 110 or 115.
Old 09-24-2018, 03:42 PM   #5
itsnt4me's Avatar
For sure on the rejet. Just put a new NGK plug in a few minutes ago and I am already lean. Again thanks for the info.
Old 09-24-2018, 05:46 PM   #6
itsnt4me's Avatar
One More Thing
I am going to want to cut a window out and not cut the entire pipe. If you used the window method what tool did you use to cut it out. Dremel?
Old 09-24-2018, 05:48 PM   #7
You could use a cut-off wheel on a small hand grinder.
Old 09-24-2018, 08:04 PM   #8
AresROC   AresROC is offline
AresROC's Avatar
Hmmm, I like the cat, lol. Don't want to be too smelly like my GSXR, but since this is only a 250 maybe there is not smell?
I would drill out the muffler just for the deeper noise... anyone have resource on how to pull the internals out?
BaShan BSR 250 DB-41H 2018 Red BS250GY-18D
JFG Racing Exhaust . Adjustable Shock 320mm . Brozz Digital Gauge . Renthal Fat Bar . 428 17x46 Sprocket . Fender Eliminator . Wheel Truing . Fuel Tank Repair .
Keihin PZ30 Main-115 Pilot-38 Needle-1Washer Fuel Mixture-1/2
BSR Chronicles - "Project leads to more projects!"
Yamaha WR250R
Suzuki GSX-R 600
Old 09-24-2018, 09:23 PM   #9
Cravin01   Cravin01 is offline
Cravin01's Avatar
might help?
Visit me on YouTube at "Project Next"!
https://www.youtube.com/channel/UC6KTCi2GVbfRDv-2XCqHhsg?view_as=subscriber
2017 Bashan Storm
Keihen PZ30 Pumper Carb,115 main jet,35 pilot jet, gutted factory exhaust, Sambo Digital Speedometer,LED blinkers, H4 headlight,D.I.D X-ring chain 428,17/42 sprockets,UNI cone filter.
Old 09-24-2018, 09:53 PM   #10
roundhouse   roundhouse is offline
roundhouse's Avatar
The hawk does not have the gas smell after removing the cat. At least not like my old R6. I still have the cat in my other bike as I get not wanting to smell like fuel after riding.
Old 09-25-2018, 01:01 PM   #11
Unlike the Storm, the Hawk cat is single wall construction so won't be as bad to do as Paul's
Old 09-25-2018, 08:48 PM   #12
Cravin01's Avatar
I didn't know that, I sure would like to see a Hawk up close to see what is shared if anything? I was thinking maybe the tanks could be swapped so I could get a fuel gauge.
2017 Bashan Storm
Old 09-25-2018, 10:34 PM   #13
when you open up the cat and see how restrictive it is you will wonder why it even run with it in and i have no smell on the hawk.
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 09-25-2018, 10:36 PM   #14
cut a big window too cause that mother doesnt want to come out of there and welding the shitty metal is a bear. i chased hole with the welder till i got tired and ordered aftermarket.
2016 hawk
kaw h1 400 tripple
Old 09-26-2018, 07:58 AM   #15
Biker_Andy   Biker_Andy is offline
Biker_Andy's Avatar
Is the Cat under the heat shield on the Hawk too?
My TT250 has a long slight bulde under the heat shield and a big stubby bulde where the muffler attaches to the mid pipe. It seem bigger then it needs to be for just a coupling. I assume it's hidden under the heat sheild because it would be way too convenient to remove if it was in the coupling.
