Old 10-19-2018, 11:49 AM   #1
Vx21rsjohn   Vx21rsjohn is offline
Wheel hop
Has anyone experienced wheel hop on the vader/razskull clones? When I ride at high speeds I believe the rear wheel hops. I Looked to see if there's any balance weights and there are none.
Old 10-19-2018, 02:14 PM   #2
Biker_Andy   Biker_Andy is offline
Biker_Andy's Avatar
Sounds scary, hopefully just a weight fell off or someone forgot to balance it at the factory. I'd put it on a stand and check your wheel bearing too.
Electrician & Electronics Tech
2014 Honda CB500XA
2016 CSC TT250
1976 Honda CJ360T
2022 Honda Navi
Old 10-19-2018, 02:19 PM   #3
Douglass   Douglass is offline
Douglass's Avatar
Get the rear tire off the ground and spin it. Check to see if you have a bent wheel/out of round wheel, or a tire hop.
Also, check to make sure that your swing arm/axle bolts are tight, and that you do not have play in the swing arm bushings.
For kicks, also check the chain slack. Make sure you are not to tight or too loose.
Old 10-19-2018, 02:33 PM   #4
Check to see if the tire is beaded evenly on the rime too.
Old 10-19-2018, 09:27 PM   #5
Thanks for the help. I've checked all yalls suggestion a few days ago. But I'll keep invastigating it. Might take the wheels off and get them balanced.
Old 10-22-2018, 11:38 AM   #6
wlfpck   wlfpck is offline
Make sure the rear wheel is also on straight. If need be, you'll need to adjust one side or both with the chain tensioner.
2020 Honda Grom
2017 Icebear Fuerza (Daix PMZ125-1) - Sold
