10-19-2018, 09:28 PM | #1 |
Hand Guards for Hawk 250
What hand guards can I get for the Hawk 250? I found a pair that I thought would fit, but they requires that I cut my grips and remove the balls on the clutch and brake levers...no thanks!
10-20-2018, 03:37 AM | #2 | |
move your levers in..or get short levers.. all hand guards/bark busters worth having need the end of the grip cut off... ..
10-20-2018, 09:35 AM | #3 |
OK. Thanks. I was not aware of that.
10-20-2018, 09:56 AM | #4 |
I put a cheap set off of Amazon on my Hawk. I had to cut the balls off the end of the levers, and punch holes in the end of the grips. Not a bad trade off at all.
10-21-2018, 04:47 PM | #5 |
I bought the knockoff acerbis hand guards on Amazon for 30 dollars and they are very quality! the brake and clutch just need to pushed inside the bars a bit, but there is plenty of room.
I dropped my bike from a stand still right on the grid screw and broke a Tiny piece of plastic, but I was in a highway collision and the bike fell on its side right on the handgaurd. The master brake cylinder was fine and the handgaurd are still good. just a couple scratches. |
10-21-2018, 04:48 PM | #6 |
I thought I'd have to cut the balls off, but I ddint have to at all
10-21-2018, 06:50 PM | #7 |
I did the Amazon knock thing too. Side by side they are identical and $60 cheaper to the Acerbis ones, just no "logo" printed on the plastic. The Chi-Cerbis hardware is trash, just barely useable really low quality.
But If you are even a remotely serous woods rider then these are standard issue. Over the years they have always "Paid" for them selves at least once a season over the last 5 bikes. And as an added bonus they cut the wind down on your hands in the winter. Ya it's not hot out but highly reduced frostbite. Over 45MPH you just freez.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite! |
10-21-2018, 08:09 PM | #8 |
These are the hand guards and levers I'm using. http://www.ebay.com/itm/253045000398 http://www.ebay.com/itm/183461011576
2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S 2004 Honda ST 1300 2016 Black Hawk 250 (sold) Keihin PE30 carb,125 main,38 slow.Pod filter,ported & decked head 10:1 CR,Direct Ignition Coil,15/40Sprockets,NGK DPR8EIX-9,De-Cat,Dual Oil Cooler,Digital Cluster 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel Last edited by JerryHawk250; 10-21-2018 at 08:40 PM. |
10-22-2018, 03:08 AM | #9 | |
I have had those on my XT660 for atleast 5 years... All most unbendable..but the mounting hard ware is crap.. I tap the end of my alloy bars for a 16mm set screw just long enough for it to bind up on the end of the thread.. put the set screw in the lathe and drill/tap a 8mm hole down it then lock tight it into the bar end then the barkbusters can screw into it... PS.. has to be alloy bars... steel have the thinner wall so the ID is to big.. .
10-22-2018, 09:26 AM | #10 |
They come with a vinyl tube spacer that slips over the insert to account for that. They will snug up pretty tight. Only issue I had with mounting was the bolts that attach the hand guards to the mounting brackets were too long and had to cut them. I have the short leavers and don't think the stock levers will fit.
10-22-2018, 03:38 PM | #11 |
Boy what a relief! Cutting the balls off is a real drastic solution. If "She who must be obeyed" mandated this, I'd think this through real carefully...ARH
