Old 10-22-2018, 12:27 AM   #1
Whisky   Whisky is offline
Whisky's Avatar
Fuel gauge issues
Filled up today and gauge bars started at full then went to empty and started flashing. Anyone have this issue?
2018 BD125-8-x21rs
ZS190/Genuine PE28
Kepspeed GP1 Exhaust
Protaper se x110 bars/grips
1/4 MotionPro throttle
Kepspeed Braced swingarm
Chimera rear hub assy
Grom Intergrated tail light
Superlite Sprockets 17/32
custom made from Japan
Chimera Swing Arm Bolt
RK MXZ Chain #420
All Balls wheel bearings
Motodynamic fender eliminator
Coremoto ss brake lines
Composimo 2.5 lower link
Grom Calipers-w/ebc pads/rotors
Michelin tire 140&120
13x4/13x7 fatties
Grom forks
Old 10-22-2018, 04:49 AM   #2
My Hawk does that occasionally. I always reset the trip meter when I fill up, so I know how far I can go before I have to top up the go-juice. Get a flashlight and check the float inside the tank. It's possible that the float sprung a leak and took on fuel, sinking to the bottom. That would be the first place I check.
First Rule of Aviation:
The Stable:
2005 Yamaha V-Star 650 - SOLD
2015 Suzuki DR 650
2015 RPS Hawk 250 - SOLD
2016 Ural Gear Up
Old 10-22-2018, 06:12 AM   #3
Whisky's Avatar
That's what I was planning to do on this fill up. I guess now I should have done it on the first fill up but have only had this bike for 2 months and wasn't expecting things to malfunction so soon. If the float did take on a leak Im guessing there is no fixing that and probably wont be able to locate a new tank. I will start there today. Thanks
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 10-22-2018, 07:01 AM   #4
The float assembly should be able to come out the bottom of the tank. It's not really that hard, just time consuming. There are parts out there, and a new float shouldn't be that hard to run down. Let us know how you make out.
The Stable:
2015 Suzuki DR 650
2016 Ural Gear Up
Old 10-22-2018, 09:05 AM   #5
Check the connector and wiring for the sending. May just be a bad connection or corroded connector or break in the wiring.
Old 10-22-2018, 09:30 AM   #6
chuck   chuck is offline
Whisky,where did you purchase your bike from?and is it the one that looks like the razkull?
Thanks
Old 10-22-2018, 10:12 AM   #7
Whisky's Avatar
Thanks
Venom Motorsports (Canada)- yes it's the clone of the Raskull. Venom has been very helpfull with another issue I had so I'm sure I will hear from them as I have emailed them on this. I'm thinking if it was a lose wire problem it wouldn't be flashing empty but I will take a look later today when it warms up.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 10-22-2018, 03:22 PM   #8
Whisky's Avatar
I did find the problem. (jerryHawk250) was correct. There is a green and yellow wire connector under tank embedded into the main wiring harness, the yellow wire was not locked into the connector. I locked it in and checked the rest of the wiring that I did not check before so all "should be good now". I'm really starting to see you must check absolutely everything on these China bikes as some have said. On mine its has become a must.
2018 BD125-8-x21rs
ZS190/Genuine PE28
RK MXZ Chain #420
13x4/13x7 fatties
Grom forks
Old 10-22-2018, 03:53 PM   #9
Glad to see you got that resolved. I've taken apart every connector on my Hawk and put dielectric grease. I found a couple that weren't locked in place.
