Issues with carb
Ive bought this carb
GooDeal Lawn mower Carburetor with Air Fuel Filter (for 110cc 125cc 140cc Pit Dirt Bike) https://www.amazon.com/dp/B01FS6M3W8..._X.L3Bb7ATPFAA And I'm using a 95 main jet. When I start the bike it idles high(7-8,000), so I thought the idle screw needed to be turned back some. That doesn't work. I've adjusted everything. Fuel mixture screw(just to see if it would help) clip position( only from middle to first) and adjusted the throttle cable. I can not seem to figure out why it's idling so high. It's pretty rich as plug is wet from fuel but I can not adjust it. Anyone experienced this? Everything is pretty snug as well so I don't believe it's a vacuum leak and I took all the emission stuff off. Just have an crankcase breather. |
Slide in backwards or not enough slack in throttle cable.
2025 Lifan KPT 400 2024 Linhai 300 ATV 4x4 2023 Lifan Lycan 250 Chopper 2023 Venom Evader 2022 Lifan KPX250 2020 Kawasaki Vulcan S (Sold) 2004 Honda ST 1300 (Sold) 2016 Black Hawk 250 (sold) 2016 Cazador180 XL 2014 Coolster150 JerryHawk250.com My YouTube Channel |
I had the exact same problem, pulled my hair out for a week, Jerryhawk said it, not enough slack in the throttle cable was what solved my problem and a couple vac leaks, also trying to adjust idle at idle screw on carb. Needs to be adjusted at throttle on handle bar first then on carb. Clip on my needle is on 2nd from the top. If you look up my thread "new carb on but" you will see exact issue you have. Its not the carb but a tuning issue. Also make sure the choke is off--down position, Also check for vac leaks.. theres a canister ziptied to the frame behind the plastic side cover.If u didn't remove it Thers 2 vac ports on it that need to be plugged. I thought when I changed my carb I got all the emission stuff off, I didn't realize there was that canister tucked in there.
2018 BD125-8-x21rs ZS190/Genuine PE28 Kepspeed GP1 Exhaust Protaper se x110 bars/grips 1/4 MotionPro throttle Kepspeed Braced swingarm Chimera rear hub assy Grom Intergrated tail light Superlite Sprockets 17/32 custom made from Japan Chimera Swing Arm Bolt RK MXZ Chain #420 All Balls wheel bearings Motodynamic fender eliminator Coremoto ss brake lines Composimo 2.5 lower link Grom Calipers-w/ebc pads/rotors Michelin tire 140&120 13x4/13x7 fatties Grom forks |
Post back with what you found or didn't find. I wish the thread title could be edited so when a fix was found it could be noted on the original thread.
My issue: I was using the stock carb throttle cap( I didn't think it mattered). It was causing the slide to not fully seat. I took it off and installed the one the carb came with, and it idles as it should. I took all the slack out of the throttle cable when i installed the carb; I was using the wrong carb cap. Now I have to tune it. I took it for a ride, and I felt a little hesitation at full throttle. All jets are the same as the carb came. I think I need to up the main jet to 100-120.
Cool now we are getting somewhere. How many turns out is the a/f screw? That will tell you if you need to go bigger/ smaller main jet. 3 turns or more=bigger/ 1 turn or less=smaller. Mine is running a tiny bit rich still but don't want to run lean. As you make adjustments to carb, my advice would be stay close to home for awhile and make your rides for a longer time so you don't get stranded. I stayed within 6 blocks and kept adding time as I tuned. If I break down now it wont be because of a carb/tuning issue. I ride 30-40 miles around city now and no worries. I also replaced the cone filter it came with with a larger foam one.
I have to look at carb tuning guides again. Carbs are pretty new to me. I know the clip on the needle is in the second to last notch from the bottom.
The higher it is towards the top the farther needle seats into jet and the leaner it will be at idle. I don't know much about carbs either, only what I've learned from here.
