12-14-2018, 06:03 PM | #1 |
Bull 150...still no spark.
Gents,
I have replaced my ignition coil, CDI, stator, and spark plug, and I still have no spark. I've tested everything with a multimeter and it is all within spec. I have no idea where to go from here. Any ideas? Thanks, Dusman |
12-14-2018, 06:29 PM | #2 |
Check the kill switch for short or that it's not on.
12-14-2018, 09:00 PM | #3 |
Would it still turn over if it's the kill switch? I'm just curious. I'm not familiar with these Chinese bikes.
12-14-2018, 09:02 PM | #4 |
Yes it will still crank.
12-14-2018, 09:18 PM | #5 |
Try disconnecting the kill switch and see it fires up. Also check all grounds connection are good.
12-15-2018, 01:28 PM | #6 |
It was the CDI. I replaced it with a stock brand new one and it fired right up. I had already put a brand new racing CD in there and it was brand new right out-of-the-box. Was defective from the factory!
Lesson learned: Multi-meter test all new parts. |
12-15-2018, 02:50 PM | #7 |
Glad got it figured out.
12-15-2018, 05:34 PM | #9 |
No problem. Bashan has a few that are 49 state legal . The Enforce is pretty much the same bike with a few upgrades.
