Old 09-29-2019, 09:31 PM   #1
vonnsue   vonnsue is offline
Question Brozz 250 idling too high -
Hi y'all!
New to the forum and just put together my bike- a Brozz 250 Blue Angel.
I've started it up no problem but she keeps revving past 7-8000 rpms in idle. I tried setting the idle back on the carb but it doesn't seem to make a difference.
I've started it several times with no change.
I also checked the throttle and it's not stuck in any way.
I'm newbie when it comes to engines/bikes and not sure what to do and I'm open to any suggestions you might have.
Thanks for your help!
V
Old 09-30-2019, 01:22 AM   #2
duck9191   duck9191 is offline
Sounds like it's sucking air from somewhere it shouldn't be. Make sure the nuts that hold the carb on are tight as well as the ones that hold the carb mounting flange to the head. Unscrew the slide cap where the throttle cable goes in, there should be a gasket in the top of cap but they can fall out.
2020 Triumph Tiger 900 rally.
2018 Bashan Storm 250. pz30b, digital cluster + gear indicator, unifilter and car customs full exhaust.
2019 Taotao 110b boulder atv. The "arm breaker" lol
2007 Honda VTX 1300R.
1974 Suzuki tm125, work in progress
2001 Suzuki Drz 400s.
Old 09-30-2019, 04:44 AM   #3
herbie   herbie is offline
7000-8000 rpm's is wide open throttle, make sure the throttle is returning to the seated ( throttle off position) at the handlebars. If you had the carb off the bike the throttle slide may be put back in the wrong position.
If the 7000-8000 rpms was a mistake on your part and it's idling high but not that high then check your choke position. The lever on the left side of the carb is the choke lever, all the way down is off, middle position is half choke, all the way up is full choke. Unless your in a very cold climate, set the check on the middle position and start the bike let it idle for a few seconds and turn the choke off.(push the lever down)
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 10-01-2019, 12:33 AM   #4
Thanks so much for the feedback guys! I had pulled the throttle cable too much when I assembled it and there was a gap on the top of the carb. Problem solved!
Old 10-01-2019, 11:25 AM   #5
wedooit   wedooit is offline
wedooit's Avatar
Hey von! Welcome here, post a pix or two!
A family that works together, plays together, shoots and trains together, and sleds together, stays together. Second amendment! SkiDoo sleds, NOW 2 TTR225, and a BMS250. A couple of quotes (we are not farmers) "I don't get off the farm much" "Am too old school" I call the china bikes "the china syndrome".
Old 10-04-2019, 03:34 PM   #6
PeaceSportsAtlanta   PeaceSportsAtlanta is offline
PeaceSportsAtlanta's Avatar
Are you fellow out by Las Vegas who called me? Very tough to diagnose bikes by phones. Glad the forum was able to help get it solved!!!
www.Brozz250.com
Email: jeffreyp@peacesports.com
Phone: 770-662-1898 x107
Facebook: "Peace Sports"
IG: Peace_Sports_Atlanta
Youtube: "Peace Industry Group"
Old 10-06-2019, 07:39 PM   #7
Red Hawk   Red Hawk is offline
Red Hawk's Avatar
My mixture screw fell off my carb when I was out on a ride. I know I know HOW!? The bike was stuck a 4K every time i was at 0% throttle. Fun day. Was hard to spot too.
2018 Hawk P&P Decked .040 off the head. 17/43 D.I.D. 428, NGK Iridium plug, DeCat, Wrapped pipe, Custom S.S. Muffler core, Nibbi PE30 115/35, L.E.D. Lights, Digital Cluster, USB port, Cutting Bord skid plate, Oil cooler w/ custom CRF oil filter inline, 5Wt fork oil, Rear Shock, CNC Back Rack, 30mm FAT bars, Bark Busters, ProGrips, Adjustable levers, Shinko 700’s lots of Loctite!
Old 10-14-2019, 06:26 PM   #8
Breaking in the new engine
Hey Y'all,
Any advice on breaking in a brand new Brozz 250?
Old 10-14-2019, 08:53 PM   #9
just wondering if anyone has an older one and can answer this question. do these blue plastics hold up better to the sun than the black hawk ones. mine are turning greyish with swirls!
2016 hawk
kaw h1 400 tripple
13' long chopper in progress
2009 johnny pag bar hog
Old 10-14-2019, 09:21 PM   #10
Hey Y'all,
Ride it. Don't baby it, don't beat the hell out of it, no sustained full throttle and vary the rpms. Change the oil often for the first few times, they don't have a filter so all the crap stays suspended in the oil.
brozz 250
