Delphi MT05 sequence for imperial/metric
Is there an ignition key sequence for changing MPH to KPH (imperial/metric) reading for a Delphi MT05 ECU? The bike is a Brixton BX125, had to perform a hard reset of the ECU to clear out a fault code and that switched my clock to miles per hour.
I don't have an OBD2 reader or the right software tools to read/write MCU settings, really hoping there's a sequence for this setting as well. Last edited by brixtonrider; 12-07-2019 at 10:26 AM. |
Not in ecu I’d say? Weird
I don’t recall seeing it in live data Prob press button on dash then turn key on.. |
Will try that. Thanks a lot, really appreciate it!
Many thanks, that worked beautifully.
For clarity to other readers, the full sequence for switching between imperial and metric readings on the dashboard - 1. Turn iginition off for at least 15 seconds 2. Turn ignition on/off two times really quick (half a second or so each cycle) 3. Wait 15 seconds (with ignition off) 4. Turn ignition on, your readings should now be in the new measurement system |
