Old 01-21-2020, 11:23 PM   #1
Shawnd84   Shawnd84 is offline
New member Hawk DLX 250 EFI
New member here!
Looking for any help with decat on an EFI bike? Anyone take the plunge? I did the air box mod without any issue? I worry about the EFI not dealing with it well and the lack of reflash for the Delphi ECU on the Hawk if i cut out the cat... Any words of wisdom would be great !
Thanks in advance
Shawn
Old 01-22-2020, 04:01 AM   #2
Welcome to the forum! The fastest way to tell if you'll have a problem is to look at the exhaust and locate the O2 sensor(s). If you only have one O2 sensor, and it's in front of the cat, you won't have any problems gutting it. If there are two O2 sensors, one in front and one downstream, you'll trip the check engine code and run in open loop all the time. I can't imagine these bikes having two O2 sensors, that's usually reserved for the higher-end BMW's and such. Let me know if you have any issues locating the O2 sensors.
First Rule of Aviation:
The Stable:
2005 Yamaha V-Star 650 - SOLD
2015 Suzuki DR 650
2015 RPS Hawk 250 - SOLD
2016 Ural Gear Up
Old 01-22-2020, 07:37 AM   #3
Welcome aboard! I think you only have the one O2 sensor before the cat. The ECU should adjust to the changes on its own.
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 01-24-2020, 09:43 AM   #4
Dlx efi decat??
There is only the one O2 sensor before the cat ! I'm gunna gut it and i'll let you know what happens!
Thank guys!
Old 05-17-2020, 05:03 AM   #5
MINTY DLX   MINTY DLX is offline
updates?
Old 07-25-2020, 01:15 PM   #6
Newrider6896   Newrider6896 is offline
Need new o2 sensor
Please help, dropped my bike and thrashed threads on o2 sensor. Where can i get one for hawk 250 dlx efi 2020-2019?
decat, dlx, help!
