Go Back   ChinaRiders Forums > Media/Reviews/Classifieds/Sponsors > Web Deals - NEW!
Old 10-04-2020, 02:33 AM   #1
Musictrek   Musictrek is offline
Musictrek's Avatar
Brozz got new Tusk handlebars and brush guards
Last weekend the Brozz took a small drop as I was horsing around in the dirt, but already bent up the inexpensive 20.00 Amazon handlebar brush guards I had installed. So, I'll give Tusk a try. New Tusk KX high bend bars with Tusk brush guards. The KX bars are a little longer than the other Tusk bars and a bit higher than the other Tusk bars. I installed the brush guard brackets opposite of the picture on the instructions so it could clear the brake hose. The crazy thing is that the brush guard brackets were wanting to line up directly in line of the Tusk handle bar pad brackets. Fortunately, there was enough adjustment in the brush guard brackets to mount next to the pad brackets on the handlebar. Did the little drill hole thing on the new handlebar for the light/horn/turn signal cluster so it wouldn't rotate at all.
https://radpaul.weebly.com/brozz-and-hawk-250.html
