Smaller Hawk Wheels, Shock, And Brozz Swing Arm
Hello, Can Anyone post a link to some smaller wheels that will work on The 2020 Grey standard fork Hawk? also a link to where I can get a Brozz Swing arm for the hawk, and a shorter shock (280-300mm) that will fit the Hawk. The Goal is to lower it. If anyone feels the swing arm is not neccessary, let me know. If it can just be lowered only with the shock, that's great, tha'ts all I will buy. Thank you much.
#2 | |
Standard Brozz front 19" wheel (also grey forks) and the rear Brozz Recon/Blue Eagle 17" rear wheel will fit on a Hawk. How much are you trying to lower the bike?
I think 2.5 inches would be good for my friend
Then a 295-305mm rear shock should do just fine, and if you absolutely need to, raise the front fork tubes an inch in the triples.
Is there a certain one that I should be looking for? Does it have to be a certain bolt hole size or are they universal? Can you please post a link to one?
