03-06-2021, 01:17 PM | #1 |
Carb hose disconnected on new 250
Hello and thank you in advance.
I don’t know much about carburetors. First bike. This is a brand new Motomax 250. The hose going from the front of the carb (where the carb connects to the cylinder) is just laying disconnected. I’m assuming the bike would idle much nicer and stay running with it connected. It’s under vacuum and if you plug it the bike dies. I have included a couple pictures. I also notice a small nipple in the back upper right of the pic showing the disconnected hose. Is that where it goes? |
03-06-2021, 02:25 PM | #2 |
My fuel line running from the tank to the carb was not attached to the carb ,but all other lines were.. You may want to make sure the bowl drain valve is shut on the carb. Mine was open ,and I lost some fuel.
03-06-2021, 03:11 PM | #3 | |
2019 Z 400 2020 Tan Recon 2021 KLX 300 2022 GPX FSE 450R |
03-06-2021, 04:00 PM | #4 | |
Thank you for the help. |
03-06-2021, 05:48 PM | #5 |
That’s it, keep it plugged in. Adjust the idle. If should be 1500 rpms when warmed up. My bike always idles low when cold.
03-06-2021, 06:51 PM | #6 |
So I used my Mac tools multimeter. It has a clamp for the spark plug to check rpm. I’m not able to adjust it below 2000rpm without the bike dying. Any thoughts. Thank you.
03-06-2021, 07:05 PM | #7 |
Did you adjust the valves ? Have you rejetted the carb yet ?
03-07-2021, 03:01 AM | #8 |
If the valves/jetting and then air-idle mixture screw aren't properly set, it will have trouble idling.
