Old 05-02-2021, 03:53 PM   #1
BakedOregonian   BakedOregonian is offline
Quieter exhaust?
Hey guys! I'm seeing these ADV bikes out here barely making any noise and my Hawk sounds loud as hell! Is there anything I can do to quiet her exhaust down a bit?
Old 05-02-2021, 05:03 PM   #2
Is the exhaust stock?
2021 Tao Tbr7 - "Lucille"
2009 Q-link Legacy 250
Old 05-02-2021, 05:04 PM   #3
Yes it is.
Old 05-02-2021, 06:01 PM   #4
Originally Posted by BakedOregonian View Post
Yes it is.
Those are known to be pretty quiet stock. I wonder if it has something wrong inside the muffler. You might see if someone with a csc, brozz, or tbr7 has a stock exhaust they'd want to part with.
Old 05-03-2021, 07:41 PM   #5
Thank you, that's a great idea. Let me ask, am I limited to those? These bikes (very similar to my Hawk) are extremely muffled and it just seems unlikely that they have one of those exhausts.
Old 05-03-2021, 08:08 PM   #6
I'm pretty sure the csctt250,tbr7,brozz 250s, and hawks are pretty much direct bolt ons to each other. With so many on this site replacing their stock systems with aftermarket units, you could prob post up you're looking for one and someone would make you a deal.
Or search csc's site or brozz250.com and see what a new one would cost you.
Good luck!
Old 05-12-2021, 10:52 PM   #7
I just put a baffle in the baffle. Dropped the decibels by 40% and got 2-4 more rpm's.
Old 05-14-2021, 12:09 AM   #8
Slofun   Slofun is offline
Can you please explain what you did exactly? I'm very interested. Pics would help. Thanks!
Old 05-14-2021, 02:23 PM   #9
Bill Hilly   Bill Hilly is offline
http://http://I have a Brozz, and gutted the cat, as well as cut around the small outlet pipe , and removed it from my muffler. I ended up with about a 2.25" opening in my muffler , and it was loud, but along with the carb rejetting ,I got a noticeable increase in power, It sounded good, but was too loud. I welded a muffler adapter in the opening, with the 2" end inside the muffler, and the larger end forming the outlet of my muffler. I then made a baffle from a short length of tight fitting pipe. I just welded a "lolipop baffle" in the short piece of pipe to make it. I cut it off to extend just about a quarter inch past the main outlet, so I can easily remove it. It really reduced the noise,and is pleasant to ride on. I don't notice a decrease in power, but I think it actually pulls a little smoother , but that may just be because it is quieter. I will take a picture later.http://
