Old 06-07-2021, 08:37 PM   #1
Ianprib   Ianprib is offline
Question Apollo 250 exhaust valve and piston
Tore down the motor on my apollo 250rx and found that my exhaust valve was bent and began to make contact with the piston. Anyone have any links to valves and pistons that would fit? No info on them when I try to search the internet.
Old 06-08-2021, 08:06 AM   #2
Verify the size of the bore. It should be 65.5 mm if an older engine. the newer engines will be 69mm. If 65.5 mm then any piston for a 2003-19 Honda Crf230f will fit including the Wiseco 11:1 piston. The same with the valves but verify your measurements to make sure.
https://www.ebay.com/itm/382670730611
2020 Kawasaki Vulcan S
2004 Honda ST 1300
Old 06-08-2021, 12:07 PM   #3
alex_in_az   alex_in_az is offline
any idea when the change over happened? is it reflected in the engine number at all?
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
4 degree advance key
290 degree cam
Nibbi PE30 and cone filter
Front fork brace
Old 06-08-2021, 12:33 PM   #4
I think they switch somewhere in mid 2020. If it has the oil site glass it should be the 223cc, if no site glass it will be a 229cc. My X22R is a 223cc and my Ghost is a 229cc.
2004 Honda ST 1300
Old 06-08-2021, 07:46 PM   #5
I have the newer 2020 with the sight glass. You say its a 223cc piston?
Old 06-09-2021, 08:40 AM   #6
So yours is the same as my X22R which would be 223cc. Just measure the bore to verify.
2004 Honda ST 1300
Old 06-09-2021, 03:36 PM   #7
so I'm guessing there's no way to fit the 223 jug and piston to the 229 to get 254cc?
2020 Tao TBR7
9.3:1 PnP head
CRF230F exhaust
290 degree cam
Front fork brace
Old 06-09-2021, 03:48 PM   #8
There are Big bore kits that will get you to about 240cc's.
https://www.ebay.com/sch/i.html?_fro...e+kit&_sacat=0
2004 Honda ST 1300
apollo 250 rx, enduro
