06-29-2021, 11:34 AM | #1 |
2020 hawk deluxe
Runs good but sometimes when cold it hesitates and when it’s warm sitting at a idle and when I hit the throttle it cuts off , I did valves did not solve the problem, might do them again
06-30-2021, 01:06 PM | #2 |
Any ideas what could be causing this, I thought efi would solve the hesitations and stalling issues
06-30-2021, 01:55 PM | #3 |
How many miles do you have on it? Mine kinda does the same thing and only 20 miles.
06-30-2021, 02:41 PM | #4 |
It might takes some miles for the ECU to learn. Give it some time.
06-30-2021, 10:23 PM | #5 |
100 miles
06-30-2021, 10:41 PM | #6 |
I tightened back wheel to 69 foot lb and wheel seems to have drag on it does yours have drag
07-01-2021, 10:43 AM | #7 |
Hi, no just checked this morning. My torque on the bolt is 65 and I don't think 69 would make a drag. How's your chain tension?
07-01-2021, 11:34 AM | #8 |
Chain is good ,,,from what I saw it is supposed to be 68.59 I rounded to 69 foot lbs
07-01-2021, 11:46 AM | #9 |
My manual says torque 65 ft lbs on rear axle 45 on front.
07-01-2021, 05:43 PM | #10 |
You are right I
Got the information from this forum but it really didn’t make a difference |
