06-30-2021, 08:30 PM | #1 |
(drum brake 17" 2.15") rear wheel shark 250?
where can i get a rear wheel with drum brakes for a shark 250? the sprocket is only like a few inches out from the center of the wheel. its a 17" wheel thats got a 2.15" wide rim. not sure where i can get one or how to check to see its the right one. i saw some on aliexpress but they look like the sprocket is out more than the one on my bike. any assistance would be helpful. either that or how would i just replace the thing with one that uses a disc brake? can i get a swingarm that would let it fit and adapt the brake to work? id rather just get a new wheel tbh. the rear wheel was basically obliterated. people cant park for shit and ran it tf over thankfully i just need that wheel and a brake lever and mirror.
07-01-2021, 10:49 AM | #2 |
Older Brozz 250 had rear drum brakes. https://shop.brozz250.com/eshopprod_...ear_Wheels.htm
I would also check on partskit.com. The older TBR7's had rear drum brakes.
07-01-2021, 01:56 PM | #3 |
is there a name brand motorcycle that uses the same wheel as a brozz 250? like can i buy a name brand one somehwhere or figure out what name brand one has this so in the future i dont have to worry about parts? the place i called said they have one left. kinda weird.
07-26-2021, 10:36 AM | #4 |
just so everyone knows for future reference, the brozz 250 enduro has the same wheel as the shark 250 enduro. its the same. to the t. the drum brake from the shark fits the brozz wheel too. also the kickstand from the brozz appears to be the same as the shark.
07-26-2021, 01:22 PM | #5 |
It could be the same as an '86-'02 XR200 wheel if someone wants to compare.
07-27-2021, 12:03 PM | #6 |
Do you happen to have a photograph of the bike wheel?
Tags |
17", 2.15", drum brake, rear wheel, shark 250 |
