Old 07-05-2021, 12:12 PM   #1
weiser23   weiser23 is offline
Service manual for hawk
Back when I got my qlink Andrew found and uploaded a service manual for the Xp 200 which was a amazing tool to fall back on for the weekend tinkering mechanic,
Is there and such a thing that even exists
Old 07-05-2021, 01:02 PM   #2
I'm not the expert on such matters but I found this manual reference for a CGR 125 and maybe has some useful info.
https://josemaco.files.wordpress.com...h-62ktjam5.pdf
Old 07-05-2021, 03:04 PM   #3
Thanks any information is important,
I’m looking for back wheel information my wheel is dragging more than I think it should be unfortunately the back wheel in this asq manual has drum breaks ,but the manual will help with a lot thank you
Old 07-05-2021, 03:08 PM   #4
herbie   herbie is offline
How about this
https://cscmotorcycles.com/content/u...uals/tt250.pdf
2022 Venom KPR 200 Red- the fastest color
16t and 46t sprockets, NGK Iridium CPR8EAIX-9, aftermarket full exhaust system. Top speed 81GPS
2023 Venom SS3 KP mini 150– Nibbi carb, Nibbi air filter, aftermarket muffler, decat
2022 Venom Ghost chopper 250
1997 Honda GL1500 Goldwing
1978 Kawasaki KL250
https://youtube.com/@herbiesgarage681
Old 07-05-2021, 10:51 PM   #5
Bingo that exactly what I’m looking for thank you
Old 07-06-2021, 05:25 AM   #6
Everything is not exactly the same I'm sure since this is not a Hawk but maybe there is enough similarities to help you out with some things.
1978 Kawasaki KL250
Old 07-06-2021, 03:32 PM   #7
stewbrash's Avatar
Can't figure out how to delete this...ignore.
Old 07-06-2021, 03:46 PM   #8
stewbrash's Avatar
In the CSC/tt250/pdf that Herbie provided, it says on page 29 (adjusting the chain):
"When the rear wheel is aligned and the chain slack is correct, tighten the rear axle to 35 ft-lbs."-this seems a little weak for a 14mm bolt.
I have torqued my rear axle now 3 different times and now I'm worried about crushing my bearings at 69 ft-lbs. What is truly the correct #, as I've seen 35-50-69 ft-lbs recommended? I think using Loctite and 50 ft-lbs would be just fine.
Old 07-06-2021, 04:28 PM   #9
I’m not sure my torque wrench is right my wheel is petty tight and a friend came over and we we decided go with 50 55 lbs until he brings his torque wrench over , there’s not near as much drag on it now
