Old 08-07-2021, 05:10 PM   #1
weiser23   weiser23 is offline
Fuel valve question
Page 7 of my 2020 hawk deluxe manual Says . On- gas can flow to the nozzle
Off - gas can’t flow to the nozzle
Res - gas can flow to the nozzle you you have run out of gas in the tank
So there is a on , off ,, reserve on this bike , I can’t find a conventional valve on my bike
Old 08-07-2021, 08:57 PM   #2
Badluck   Badluck is offline
They probably recycled that part of the manual from the regular Hawk.
Old 08-08-2021, 11:15 AM   #3
J4Fun   J4Fun is offline
There is not one on my DLX either!
Old 08-08-2021, 11:38 AM   #4
stewbrash's Avatar
I guess that solves the clogged petcock theory.
Old 08-21-2021, 08:35 PM   #5
Why don’t the hawks have a reserve on its gas tanks
Old 08-21-2021, 09:01 PM   #6
My carbureted hawk has reserve setting on the petcock and it works. The fuel injected hawk dlx has a fuel pump in the tank.
Old 08-21-2021, 10:51 PM   #7
krat   krat is offline
Petcocks work fine with gravity feed systems but when you put pressure on them from an in-tank fuel pump there will be problems.
There is also the thing about a fuel pump not needing to push on a blocked source when someone fails to turn on the petcock at startup.
%90 of the Chinese motorbikes ever made are still on the road. The other %10 made it back home.
