12-29-2021, 11:15 AM | #1 |
Kids ATV - Need more tourque
I purchased 2 of the 36v 500wtt atv from saferwholesale dot com
The front sprocket looks like 11 teeth and rear is 54 teeth. Motor is 500w, 36v The quad gets stuck going up most of the hills in my yard, and my driveway. I guess it's pretty steep. I don't need a dramatic improvement in climb but definitely something. Anyone know what this quad is and what I can upgrade with? Chain type/size etc? Last edited by mike.katulka; 01-06-2022 at 01:21 PM. |
12-29-2021, 12:04 PM | #2 |
Can you remove the front sprocket and take a pic or measurements?
12-29-2021, 08:14 PM | #4 |
It looks like it has three speeds that are controlled at the right hand grip. I would test each one, you might find a sweet spot for what you want to do. I agree with Falkon45, that ratio is pretty good already.
2012 Kawasaki Versys 1984 Honda Magna V65 2016 Rhino 250 2016 Tao Tao 125D Last edited by david3921; 01-07-2022 at 01:31 AM. |
01-06-2022, 01:26 PM | #5 |
I'm curious about the overvolting. One kid is about 45 lbs and the other is about 80lb. It's my older one that I would consider higher volt (and speed).
The gears are attached. |
01-06-2022, 09:56 PM | #6 |
There's probably a safety in the controller that cuts the power. I don't know much about those, though, other than the simple stuff.
