04-30-2022, 03:14 PM | #1 |
Coolster 110 cc 2013 help
I have a 2013 110 cc coolster. One of the bolts that holds the engine to the frame has vibrated out. I need to replace the bolt. I don't know much about engines and am not sure what to search for to buy the bolt I need. I can post pics if needed. Any help would be appreciated.
Thank you. |
04-30-2022, 10:58 PM | #2 |
Coolster has a website with diagrams and parts lists.
https://coolster.com You'll have to register to get access but you should be able to find the bolt size. After that, go to a nearby big box store to get a bolt. TSC and Ace are common sources.
05-01-2022, 11:00 AM | #3 |
Thank you for the help.
05-01-2022, 12:02 PM | #4 |
Which bolt is missing? The one that goes on the top of the engine, or the one that goes on the back of the engine?
Can you measure the total width between the engine mounts where the missing bolt goes and post up the number here? |
05-01-2022, 04:21 PM | #5 |
If you can't find it on the website, show a picture of the location of the missing bolt. I can look at what bolt is at the same location on my grandkid's 125ccTaotao as most of these machines are pretty close.
05-04-2022, 01:11 PM | #6 |
Thanks guys, it was the lower bolt. I measured it and found one at the local Menards. As it turns out I need to replace the Carburetor. The link for the coolster page helped me locate the proper sized one and should have it in on Thursday. Thanks for all the help.
