06-18-2022, 06:49 PM | #1 |
Where is my oil filter?!
I did an oil change, or started to, but then realized that I can't seem to locate the oil filter in this engine. Where the heck is it? I see the hawk has a filter cover on the right side of the motor under the cylinder and don't seem to have that. Do I need to take off the whole right side cover or can I just assume the engine doesn't have an oil filter?
06-18-2022, 07:27 PM | #2 |
Should be near the bottom left side of the engine, a large cap facing the side with a 17mm head. Just a screen not a filter. There is a centrifugal filter on the right side under the side cover attached to the crankshaft.
06-19-2022, 08:43 AM | #3 | |
I took the 17mm head off and pulled the screen out. Do I need to take off the kick start and the clutch to get the right side cover off? Seems like a PITA... |
06-19-2022, 09:06 AM | #4 |
Unless the drained oil is pasty thick and the screen is full of scrags there should be little reason to service the centrifugal oil filter which typically gets look at when servicing the clutch pack.
Regular oil changes is typically enough of a flush to keep the engine operating. |
06-19-2022, 09:22 AM | #5 | |
The only recommendation I make when doing oil changes is to drain the oil from both the sump and remove the screen cap. The sump drain bolt is the one on the bottom of the engine, and even if you remove the cap a decent amount of oil and sediment will remain in the sump area. It's not a bad idea to inspect and clean the screen each time.
06-19-2022, 09:26 AM | #6 |
Pulled off the clutch cover and to my surprise there was no filter behind it, but there was an interesting 'mod' done to the cover itself by a previous owner. I pulled the crankshaft cover on the other side already, there was nothing under there either. Looks like this engine doesn't have a filter after all... strange! I guess I'll just fill it with oil and pray that there's no grit in there.
06-19-2022, 09:29 AM | #7 | |
I did see little bits of sediment in the screen which I knocked out a little bit. I can pull it again and take a photo of what remains and flush with WD40. I've ridden this off and on four four years without a filter change but this is weekend riding not serious miles. |
06-19-2022, 09:31 AM | #8 |
The centrifugal filter is the round 'disc' on the right with three Phillips-appearing screws. They're actually JIS, which is just different enough that if you attempt to remove them with a standard Phillips screwdriver, you'll just strip them out. I would suggest buying a "Vessel JIS #2" off of Amazon if you get the hankering to remove it. There's also a paper gasket inside of it.
Also, the "filter" doesn't get changed, just cleaned. |
06-19-2022, 09:48 AM | #9 |
Circled in black is the centrifugal filter.
06-19-2022, 11:23 AM | #10 |
I don't pull the oil screen on my CG engines when I change the oil since I've never found any debris in any of them. I may clean out the centrifugal filter every couple of years or 10,000 to 20,000 miles. What I find in the centrifugal filter is maybe 1/4 teaspoon of fine powdered metal stuck together around the edge. The main thing is just change the oil every 1000 to 1500 miles.
06-19-2022, 11:37 AM | #11 | |
With having my oil cooler installed and my engine past break in, I rarely check the screen on the line to the cooler anymore and simply just drain it at the sump. I might check it again here soon, but the last time I did it was clear.
06-19-2022, 11:45 AM | #12 | |
Heck, even the oil change intervals that many of us do here every 1500ish miles are technically on the excessive side. CSC states their oil change interval after break in around 2500 miles in "normal" riding conditions for the TT250. I run Rotella T6 15w40 Synthetic with a large oil cooler. I have pushed my oil to 2k miles now and just now changed it. Aside from a little fuel saturation, it's still in decent shape, if a bit on the dark side. Granted, if all you do is crawl around in the mud in summer temps and beat the crap out of it at high RPM and low speed, the oil will need more attention much sooner, but if you are just puttering around on easy trails or daily riding it on the street, that oil can go quite a bit longer.
06-20-2022, 11:15 AM | #13 |
My next question was going to be about the interval but that answers it! While I had the side cover off I got a dremel in there and ground down the frame a little bit to allow my oil plug/thermometer to thread into the cover and now I can monitor oil temps in the crankcase! I had the thing idling and saw it rise to about 30C, but another question I have is what is the 'danger zone' for that oil? I used the generic brand 15w40, not the full synthetic either. I will update with temps from the next ride I go on. Thanks everyone!
