04-16-2023, 04:00 PM | #1 |
qiye drain plug ?
Did my break in oil change, but removed the wrong drain plug at first. its in the left corner of block some beige milky fluid came out no help with owners manual with what it is. Any help is appreciated
04-18-2023, 09:01 PM | #2 |
If it's a 14mm bolt it's probably the cam tensioner. Assuming it was the break in oil coming out.
04-19-2023, 08:44 AM | #3 |
Not sure what you have as you did not mention it. We really need more information on what you have in order to help you. If its an air cooled engine then the milky oil is only moisture in the oil from condensation.
04-20-2023, 01:37 PM | #4 |
Wrong plug
NO need for further info.... this is the cam shaft plug... alot of people do this.. someone does not tell them which plug to drain the oil... and people do not see youtube video.. for HOW TO DO STUFF... they figure how hard could it be... and then they find out... always got to youtube video.. on how to learn something.. put plug back in .. and leave it be..
