Old 06-05-2008, 08:35 PM   #1
steelrfn   steelrfn is offline
my sons taking after his old man
Here's what my son did during my last underway period
He had torn up the rear rim on his 110cc original ebay pitbike.
We bought a used 125, and swapped in his engine when that one wouldn't work.
He got bored and put the spring arm and rear tire off the 125 onto the 110 frame, and absolutely thought it was the coolest thing ever
Now he broke the 12" rim as well
Old 06-06-2008, 08:55 AM   #2
katoranger's Avatar
He was trying to build a hill climber.
Allen
Old 06-06-2008, 02:30 PM   #3
Allen
He says he was going for "drag bike"
Either way, I am now making him put the 125 back together.... then I am going to make a three wheeler out of the little one :twisted:
Old 06-06-2008, 03:25 PM   #4
ImEazy   ImEazy is offline
I was thinking drag bike as well.
Here's a pic of a pitbike three wheeler I found on Planet Minis a while back.
Interesting choice of rear tires if you ask me.
2000 MZ Baghira
Old 06-06-2008, 04:03 PM   #5
That's almost exactly what I am going for. A new rear rim for his smaller frame is almost 100, and I already have all the necessary parts on the go kart frame he broke in half while I was at sea last time.
Old 06-06-2008, 11:48 PM   #6
Never mind, wound up rewelding the go kart together because the swing arm to the smaller frame is missing :x
Old 06-07-2008, 05:11 PM   #7
damn! looks like that rear swing arm is gonna run around 100. That project just went straight to the bottom of the priority list.
And now I know where the engine is coming from for the 4 wheeler.
Old 06-09-2008, 09:36 AM   #8
Anyone have an idea how difficult it would be to fabricate some kind of swing arm assembly to mount to the rear axle? I am thinking that it wouldn't be too hard to fab something up that will work, and then it's just a matter of restricting the speed.
Old 06-13-2008, 09:44 PM   #9
Went to Northern tools today and bought the rear axle setup. Total cost $254.
Tomorrow it's time to begin making the new swing arm and lining everything up to install it.
2005 XS Bobcat 200cc
2005 mini pitbike 110cc
2005 pep boys special 125cc, (engine shot)
2007 110cc 4 wheeler<br />70cc pit bike<br />90cc electric start ATC110<br />
Old 06-13-2008, 10:51 PM   #10
Speaking of the new swing arm, anyone have an idea what would work to mount it? I don't have the original swing arm, so, barring a new plan I am going to just mount some go kart wheelbearings in a piece of tubing and mount it crossways at the end of the new swing arm.
Hope that'll hold up.
Old 06-14-2008, 09:49 AM   #11
katoranger's Avatar
Considering that most china swingarms use bushings the bearings should be an upgrade.
Allen
Old 06-14-2008, 12:42 PM   #12
That's what I was thinking.
Will post some pics once I get things mocked up.
Old 06-15-2008, 11:59 AM   #13
Time for a quick update.
The frame in the first post has a pair of bike handlebars welded to the old handlebar brackets due to an incident with some pavement. The welds held up fine but the handlebar bolts broke now, and I didn't allow for them to be changed.
Since the rest of that frame is about equally crappy we built the trike out of his larger 125 frame.
Mocked everything up last night and welded the brackets to hell and back only to find out I measured them wrong and they allow the back axle to move up and down.
Going out there today to try and figure out a fix for that problem.
Will post pics when I un-screw this thing up.
Happy Fathers Day everyone.
Old 06-15-2008, 09:20 PM   #14
Got it done with the exception of him never filling us in that he took the brakes off both frames :x
Put the handles and all on the front tire for the hydraulic brake that was on it, but the handle reservoir is shot so I need to pick up another.
Going to get a go kart brake for the rear wheel next payday.
Here's the finished product.
Old 06-15-2008, 09:24 PM   #15
Heres a closer shot of the rear end. It's a 1" go kart axle with an ATV live axle hub on one side and a hub that freely spins on the other, (so it will steer better), also have a standard go kart sprocket on there at the moment because it was alot easier to modify than one of his dirtbike sprockets.
The brackets came with the mounting kit, and I added 2" L shaped pieces and welded them on, then used the mounting holes for the axle to allow for adjustment of the chain length.
Anyone considering building one of these I recommend that you use C channel rather than the L shape because that will reduce the ability of the brackets to move.
