06-16-2008, 09:38 PM | #1 |
Can't find the right size front sprocket?
I may have your solution. I recently bought a new Kenda TrackMaster II knobby for the back. It's an amazing tire but the knobbies are so tall that it changes my gear ratio substantially. I called Bruce up from EJ cycles as seen in the parts thread. I had a 17T and was looking for a 15T FS. He told me that he could not get me a 15 only 14, 16 or 17. He told me as far as he knew they did not exist. I figured it out and a 15 would be optimal and he agreed. Then I looked on eBay and found a ZG in 15T. Bruce said even though it was the same size shaft it would not work. Well I wanted to find out for myself and I did. Turns out the notches are slightly smaller cut but you can get them in any tooth you can imagine for about $11 bucks sent. Well I realized that the size difference was slight and got out my dremel again I took a small grinding bit and ran it on the edges of each notch making them wider. I made sure to do one at a time evenly and when I was done I was amazed it fit on there perfect, like a glove! Took me about 5 minutes as I was being careful.
Now you can buy any size front sprocket you could ever need, as long as you have a dremel that is. This should help a buncha people. CHOW! After cutting it.. Fits like a glove! |
06-16-2008, 09:56 PM | #2 |
I bought a 15T from Bruce last fall.
Allen
06-16-2008, 09:59 PM | #3 | |
06-16-2008, 10:00 PM | #4 |
Maybe. I haven't used it yet.
What else have you done to your bike? Allen
06-16-2008, 10:42 PM | #5 | |
Perreli Scorpion front tires Kenda Trackmaster II rear Digital Engine Temp Guage Oil Cooler, (tapped into engine) 118 Main Jet K&N style Filter Front shock spacers, thicker oil (stiffer for jumping) GY7 weld in bottom frame section Orion wavy style brake rotors Performance Spark Coil Custom battery box (Still located on the side) Aluminum rear sprocket Full aluminum racing exhaust from a 250 Orion bike Komoto 20 hp 250cc engine 2003 KX 400cc stock Rear shock, (direct swing arm mount) Stage 2 Cam Performance CDI Halogen 65 watt headlight Flat black paint in back to eliminate reflection Bored out carb Bored out intake piece Ported engine intake and exhaust to match Performance clutch springs Performance clutch pack Aftermarket grips (thicker and stickier) Bike is raised 3 inches front and back. Longer kickstand to make up for the height difference GPS direction system + speedometer. Gold O ring chain Cloth mini trunk bag Fuel reserve tube modified for 15 mile reserve distance Braided brake lines front and rear Clear fuel line with filter Shaved clutch and brake levers A few other interesting mods are coming soon :wink: |
06-16-2008, 10:47 PM | #6 |
Wow do you have any pics?
Kman 2007 HI-BIRD 250 2007 Vbike V4S 250 |
06-18-2008, 02:52 PM | #7 |
so what the heck is the ZG sprocket from?
Can't find a ZG brand sprocket anywhere, might you know what application it was sold for?? I see a 15 tooth 420 chain 'pitbike' sprocket that sure looks like yours, but looks...well...not so good when talking mechanical fitment .
duck |
06-18-2008, 04:09 PM | #8 | |
Re: so what the heck is the ZG sprocket from?
13T http://cgi.ebay.com/ebaymotors/428-1...itemZ370059939 821QQcmdZViewItem?hash=item370059939821& 14T http://cgi.ebay.com/ebaymotors/428-1...INE-SPROCKET-P IT-BIKE-XR50-CRF50_W0QQitemZ360060919764QQcmdZViewItem?hash=ite m360060919764& 15 T http://cgi.ebay.com/ebaymotors/_ATV-...temZ1602516194 24QQadnZATVQ20PartsQ20Q26Q20AccessoriesQQadiZ2869Q QcmdZViewItem?hash=item160251619424& 16T http://cgi.ebay.com/ebaymotors/428-1...m370059939801& 17T http://cgi.ebay.com/ebaymotors/_Moto...0060919752QQad nZMotorcycleQ20PartsQ20Q26Q20AccessoriesQQadiZ2863 QQcmdZViewItem?hash=item360060919752& |
06-18-2008, 04:14 PM | #9 | |
06-18-2008, 04:27 PM | #10 | ||
06-18-2008, 05:05 PM | #11 | |||
06-18-2008, 05:18 PM | #12 | ||
06-18-2008, 05:31 PM | #13 | |||
06-18-2008, 09:56 PM | #14 |
cool, just ordered one
Oke, got a 15 coming. Prolly should have just grabbed 14, 15, 16, 17 to see how the changes work but I'm in a cheap mood today...
06-19-2008, 07:47 AM | #15 | ||||
