Old 01-29-2009, 11:26 AM   #1
max_damage   max_damage is offline
Send a message via MSN to max_damage
Zongshen Sierra oil leek or not ?
Hi
Im regularly changeing my oil in my zongshen, every 3 months or 4 000km. Every time i put 1 liter of oil. Today i replaced oil after 3 months of riding. When i was changeing oil i noticed that there was smaller amount of old oil (<1 L). So i took the old oil and put it in plastic bottle with measure scale, and it was only 0.9 L of oil. So my question is, is it normal to loose 0.1L oil in three months of riding (about 3 000km) ?
Sorry for bad english :oops:
Thanks
Old 01-29-2009, 11:56 AM   #2
katoranger's Avatar
I would say you are doing really good. These little engines are worked hard so a small amount of use like that over 3-4K kms is pretty low. I tend to change every 1-2K kms. I run mine hard and will see alittle bit of oil use in that time.
Allen
Old 01-29-2009, 02:18 PM   #3
Re: Zongshen Sierra oil leek or not ?
Thanks
Max, your English is excellent! I always enjoy reading your posts.
Is your Zongshen 200GY-2 still running well? How many miles have you traveled on it so far?
Old 01-29-2009, 03:21 PM   #4
Thanks! Well, recently ago my odometer stoped at 16743km :? , i dont know why? the other odometer (small one,resetable) is working. I will reasamble it, see whats wrong.
By the way, motorcycle is running strong, excellent bike :P [/quote]
Old 01-29-2009, 03:35 PM   #5
Cal25   Cal25 is offline
If I remember correctly, someone else had a similar problem with their speedometer. The needle was loose on the shaft it rides on. Maybe a little glue to secure it again?
Old 01-29-2009, 03:37 PM   #6
I opened the speedometer, here is what i found :( , a small light bulb 5W inside the speedometer generated too much heat has melted the odometer plastic numbers. So i recomend you to replace the regular bulb with LED one before it happens to you.
Normal
Burned
Old 01-29-2009, 04:53 PM   #7
liverchip   liverchip is offline
Send a message via MSN to liverchip
Yep the oil usage is normal. Nice find on the odometer!
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 01-29-2009, 11:15 PM   #8
...recently ago my odometer stoped at 16743km...
Wow! Over ten thousand miles and the Zong is still running strong! I agree, Max, for its price the Zongshen 200GY-2 is an excellent little bike. :wink:
Thank you for posting the tip concerning the melted odometer wheel! I believe my Zong speedometer was originally illuminated by two, 3-watt incandescent bulbs. However, after they burned out I replaced them with two LED bulbs. In addition to being cooler, the LED bulbs I purchased are brighter and much more resistant to the harsh vibration I encounter when riding in the dirt. I got my LEDs from the following vendor:
http://www.superbrightleds.com/specs/bulb_specs.htm
My speedometer uses wedge base bulbs. Therefore, I bought the WLED-W4 bulbs, and I love them.
