Old 02-20-2007, 05:58 PM   #1
stixx3969   stixx3969 is offline
Rear Brake Hung Up
Hi gang.
Had a nice day in Mid Missouri so I drug the ol' Roketa out of the shed. Got her fired up and went for a little ride. A few blocks from the house after using the rear brake it hung up and started bogging me down but it didn't lock up. I limped back to the house slowly in first gear because that's all that would pull it. I didn't really overheat too bad but I need to know what to do now if it's still hung after everything cools down. I figure sitting all winter is the culprit and the piston is gooey. New Fluid? , Bleeding?
Ideas.
Old 02-20-2007, 06:30 PM   #2
blimpman   blimpman is offline
Happened to me too. I just opened the bleed valve and let the pressure out... Been OK since then. I would recommend that the fluid be replaced with known good quality DOT 4 fluid. I have done this to my front brake and the rear brake is next.
The destination is merely a by-product of the journey.
'06 KLR650 '06 XT225 '92 XT225 Serow
( MBD.... Multiple Bike Disease...)
Old 02-20-2007, 06:33 PM   #3
ob1   ob1 is offline
Seems like someone said the reservoir was overfilled. this reduced the area for the brake fluid to expand as it heated, forcing the brake caliper to absorb the expansion, dragging the brake.
Old 02-20-2007, 06:39 PM   #4
msRandi   msRandi is offline
Send a message via AIM to msRandi
one check the vent and brake fluid, can,t be over full. open bleeder and move the piston back, close the bleeder and hit the brake. see if wheel speens? if the piston keeps sticking. you need to rebild or replace it.
Love from the Arizona High Desert
Old 02-20-2007, 10:15 PM   #5
Thanx for the tips. It loosened up after I let it sit for a little while. Think I'll crack the bleeder and check the fluid. I think it'll be ok. Thanx again!
Old 02-21-2007, 07:51 AM   #6
red2003   red2003 is offline
Yup, that's more then likely the culprit. All good advice. Let us know what you find out .
Old 03-01-2007, 09:59 AM   #7
Ok, Dad and I have figured out the deal on this. If you look at the bottom of your rear break master cylinder (not the slave at the wheel) you will see where the armature pushing in has two linkages with a bolt and two nuts for adjustment. Well, even with the nuts in the lowest setting where the linkages are both resting on the top nut, the master cylinder armature is still being pushed into the master cylinder creating some pressure. So, you will need to permanantly remove the nut between the two linkages and shorten the bolt (a grinding wheel may work well) so that the two linkages are touching. This will allow the master cylinder armature to release all the way out. We believe it's not necessarily a design flaw, but more of where the weld ended up for the bracket that holds both the rear foot peg bracket and the master cylinder. If this bracket weld had been about 1/2" higher the master cylinder armature would be allowed to extend all the way out with the stock bolt and nuts adjustment. I will try to get a picture of this to show more when I do mine. Dad is in the middle of getting his taken care of. So far this has been the only "problem" that was not a result of hard riding. There's no dissatisfaction with these, but he and I are both relieved to finally figure this out.
Jason
2008 Jonway MC-70-150
2007 Roketa DB-07B (RSM-200E)
2006 Roketa DB-07A (RSX-200E)
Old 03-01-2007, 11:03 AM   #8
liverchip   liverchip is offline
Send a message via MSN to liverchip
Good find there Jason!
2009 XR650L Big Red Pig
Tusk bar risers
2007 X-Moto(Jetmoto) GY250
--mods---
15/40 sprockets
UNI Pod Filter
2007 Shineray TMS 200XYi--Betsy
Betsy Mods:______________________
Acerbis DHH headlight
FMF Powercore pipe
Uni Pod Filter
Old 03-01-2007, 01:30 PM   #9
mdsuave13   mdsuave13 is offline
Send a message via AIM to mdsuave13 Send a message via Yahoo to mdsuave13
any recommend a specific fluid? i used prestone dot 4 fluid.. it seems to be working fine, so far no braking issues whatsoever except for when my front caliper almost fell off because a bolt fell out while riding (managed to back track and find it in the road!)
My name is Justin, my friends call me Stix.
2008 Kawasaki KLR650 Candy Lime Green
______________________________
I am the official China bike registration Guru For the State of Maryland..... HA.
Old 03-01-2007, 02:07 PM   #10
ambassador   ambassador is offline
Prestone dot 4 here...
Old 03-01-2007, 03:38 PM   #11
Dot 3 or 4 is fine. I had 4 when I bled mine so that's what I replaced it with.
Yeah, VFRFlyer had his hang up twice when we were out a couple of weeks ago. The fix is pretty straight forward, but I figure 20-30min and mine should be done. I just have to set aside the time to do it. Kind of low priority since mine never hung up as much as Dad's did.
Jason
Old 03-01-2007, 05:14 PM   #12
hey jason, how are your tires working out for you? you still like them?
you have the cheng shin's correct? i've been considering getting a spare set of wheels with a set of them so i can have street tires for commuting, and the knobbies for when i play on unpaved roads (even tho they are pretty terrible tires)
Old 03-01-2007, 09:38 PM   #13
Ride is fantastic. just don't expect to do any serious mud riding. They also have better side wall rigidity for cornering. These bikes will get down if you want to corner. I worn a pretty good place on my right shoe from when I touch from time to time (exit ramps)
Old 03-07-2007, 02:23 PM   #14
cycleway4   cycleway4 is offline
Hi Jason.........I did your fix to my rear master cylinder linkeage today....
I had ridden the bike around the property here short trips,..but went out on first road trip today...brake began to drag within a few minutes...
so came back and found the problem to be just as you say....no free play in the linkeage........................took out the jamb nut [in between]..all ok now............
<div>Steve
2006 Roketa DB-07A/RSX-200E
2008 Roketa 250 Scooter
2019 Brozz 250
Old 03-07-2007, 02:52 PM   #15
Yeah our bolt had to be shortened because the two linkages would not touch otherwise. Only the cotter pin in the top and the one nut at the bottom. Both ours are working great now and Dad is finally happy!
