Old 02-07-2009, 05:29 PM   #1
DDG1976   DDG1976 is offline
Send a message via Yahoo to DDG1976
Need Help!!!!
My sons 50cc(I think) baja motorsports won't crank. I've kicked it till I'm blue in the face. It pours gas out the vent tube when you pull up the choke. I haven't checked for spark because I can't kick it and hold a screwdriver near the frame at the same time. Any suggestions?
I have all of soberday to satur up!!
Old 02-07-2009, 07:20 PM   #2
ejcycles's Avatar
Take the plug out, stick it in the plug cap and let the plug lay on the engine and kick it over. There should only be spark between the main & ground electrodes only. If the spark spatters the plug is fouled.
The choke has nothing to do with the carburetor dumping fuel out the of a "vent tube? What "vent tube" are you talking about?
Old 02-07-2009, 07:22 PM   #3
katoranger's Avatar
I think that thing needs a 125 put it.
Also check to make sure the float isn't stuck. Check the oil for gas too.
Allen
Old 02-07-2009, 07:53 PM   #4
There's a tube coming from the bottom of the carb, it usually doesn't come from there unless he drops it on it's side.
Old 02-07-2009, 07:54 PM   #5
Allen
Heck no, he already scares me to death on it.
Old 02-07-2009, 08:10 PM   #6
I think the bowl is over filling. Float might not be shutting off the flow when the gas reaches the proper height?
IronFist
The "chain" of command is used for beating spammers.
Old 02-07-2009, 09:34 PM   #7
Avoid vaque thread titles
When creating a new thread use an appropriately descriptive title. For example:
Good: How do you adjust the clutch cable on a 2005 LF200GY-2?
Good: Carburetor tuning instructions for LF200GY-5
Bad: clutch problems
Bad: bike won't start
It's in the rule, that Frostbite posted.
http://www.chinariders.net/modules.p...=viewtopic&t=2
