Old 04-07-2009, 06:43 PM   #1
capone   capone is offline
big bore kit
does anyone know where i can get a big bore kit for my 110cc atv
Old 04-08-2009, 09:14 AM   #2
katoranger's Avatar
Probably would be cheaper/easier to just swap a 125 replacement engine in it.
Allen
Old 04-08-2009, 10:28 AM   #3
The cool thingf about swapping in a 125 engine is that it will be a true four speed with a clutch. You'll be able to wring out every last pony!
Old 04-08-2009, 12:08 PM   #4
This looks interesting - WARNING ebay
Its a 160cc engine is all.
There is this also.
160cc BIG BORE HEAD KIT
Old 04-08-2009, 02:49 PM   #5
forchetto   forchetto is offline
weldandgrind found this bargain priced 125 engine on ebay the other day, copy and paste this number on the search window: 350083588498
A four-speed manual 125 cc LIFAN engine complete with everything except carburettor can't be bad for $229.95
Jincheng Monkey JC50Q-7 (two of them)
Skyteam Dax replica ST110-6 (two of them)
Zongshen ZS125-43
Qingqi QM200GY-BA Super Motard
Yamaha Virago XV1100
Triumph Bonneville SE
Qingqi QM110GY
PGO Bug rider 250 Buggy
Old 04-09-2009, 12:52 PM   #6
what about the one team cheap found will that fit and will i have to mod anything like my gear box or anything
Old 04-09-2009, 02:54 PM   #7
katoranger's Avatar
It says.
110cc BIG BORE HEAD KIT
THE LARGEST POSSIBLE DISPLACEMENT AVAILABLE
WITHOUT THE HEADACHES OF RUNNING A STROKED
CRANKSHAFT.
INCLUDES:
ALUMINUM CYLINDER
PISTON, RINGS
PISTON PIN
CLIPS
ALL NEEDED GASKETS.
MUST BORE ENGINE CASES TO INSTALL,
COMPLETE INSTRUCTIONS INCLUDED.
PROVIDES ALL PARTS NEEDED TO TURN YOUR STOCK 110cc 4
STROKE TO A 160 MONSTER.
WE RECOMMEND THAT YOU USE OUR NEW 26mm TAPER BORE
MIKUNI CARBURETOR SET.
Note the sentence in red. Also recommends using a 26mm carb too. It appears it should fit.
Allen
Old 04-09-2009, 04:21 PM   #8
This is my last comment as I see no reason to have to respond to three different threads on basically the exact same topic posted by a person who just keeps asking the same questions hoping to hear what he wants to hear sooner or later.
This really is very simple if you just run the numbers.
first starting with "how much do you have to spend"
then you go to "what can be bought with how much you have to spend"
then FINALLY you get to the "making the ACTUAL purchase"
end of story!
If you can afford a $600+ complete engine upgrade then you can probably save a bit more and just buy a whole new, better, faster quad right out of the gate.
If you have a tight budget then a more modest upgrade could be done but YOU will have to find the best combination for YOUR budget and needs/wants.
If the quad involved in this has a good suspension with REAL shocks and ohh lets say 6-9"'s of suspension travel front and back and great brakes on it then go for the monster engine upgrade but putting to much engine into a limited quad frame is asking for disaster and dissappointment.
