Old 12-19-2009, 09:00 PM   #1
Tire Changing Tips from the Pros
I think the following tire changing videos are superb. I use a combination of the techniques shown in these videos when I change my tires. These videos have made tire changing a lot easier for me, so I wanted to share them with my fellow China Riders.
Old 12-20-2009, 06:05 AM   #2
Q   Q is offline
One thing missing in both those videos is the mention of temperature. Working with a cold tire is much more difficult than a warm one. If you're changing tires in a cold garage during the winter, take the tire inside and warm it up before working on it. It makes it a lot easier.
Also if you don't have a rim lock it's easiest to start removing the tire from near the valve stem, and finish at the valve stem when putting it back on. That's because the stem prevents the bead from going all the way into the dish of the rim.
Q
Old 12-20-2009, 12:00 PM   #3
Originally Posted by Q
One thing missing in both those videos is the mention of temperature. Working with a cold tire is much more difficult than a warm one. If you're changing tires in a cold garage during the winter, take the tire inside and warm it up before working on it. It makes it a lot easier…
Thank you for the additional tips, Q. Indeed, it is always easier to work with a warm tire. If possible, I lay my new tire on the driveway to soak up heat before I install it. I read that another fellow puts his new tire inside his car, and turns on the heater!
…Also if you don't have a rim lock it's easiest to start removing the tire from near the valve stem, and finish at the valve stem when putting it back on. That's because the stem prevents the bead from going all the way into the dish of the rim…
I also don’t use a rim lock. Therefore, as with you, I always begin my work at the valve stem.
After a summer of changing tires on my knees, I decided to invest in a Moose Racing tire changing stand. I am glad I made this investment; this tire changing stand makes the job much easier.
http://www.motorcycle-superstore.com...e-Changer.aspx
I hope other forum members will also offer their tire changing tips!
Old 12-20-2009, 05:07 PM   #4
Wow! Those guys make it look so easy... Need me some irons and a dirtbike with a bald tire now!
Old 05-27-2010, 08:55 PM   #5
Hey guys, pulling up an old thread here . I ordered a set of new tires for my bike and was just wondering what kind of tire irons you guys like best? I've heard good things about the Motion Pro spoon type ones but they look a little unconventional to me. Also, are 3 irons a necessity or can you get by with 2? I vaguely remember long long waits at the bike places to get tires mounted so I might give em a shot myself.
Old 05-27-2010, 09:28 PM   #6
We don't mind when someone revives an older thread, Stew. In fact, I enjoy it when someone reinvigorates a good thread.
I really like the Motion Pro type tire spoons. They do a very good job changing my dual sport tires. Three tire spoons are not necessary; however, the third spoon certainly makes the job easier. The third spoon is especially helpful when you are removing the old tire.
Old 05-27-2010, 09:35 PM   #7
Thank you Spud, I think I will go with the Motion Pro spoon type irons. About $15 US each so I am assuming they are good quality. You've changed quite a few tires so the advice is golden to me. I think I will order 3 as well, easier is better for me . Do you use the bead buddy like in the video as well?
Old 05-27-2010, 10:18 PM   #8
You're welcome, Stew. If you shop around, you can probably find the BikeMaster tire spoons for less than $15 each. I bought the BikeMaster tire spoons, and they are virtually identical to the Motion Pro tire spoons.
I certainly do use a Bead Buddy; it makes the job much easier! The Tusk Tire Bead Tool from Rocky Mountain ATV is exactly the same as the Motion Pro Bead Buddy, but the Tusk tool costs much less.
http://www.rockymountainatvmc.com/pr...dFamilyId=3044
Old 05-27-2010, 10:52 PM   #9
Cool, on order including the Tusk Tire Bead Tool . Thank you for the excellent advice Spud
Old 05-27-2010, 10:58 PM   #10
Wild_Alaskan's Avatar
i saw some massive tire irons at harbor freight when o was in clifornia for very cheap also
Old 05-27-2010, 11:05 PM   #11
Old 05-27-2010, 11:11 PM   #12
Thanks for the tip, WA. Indeed, I saw those tire irons during a recent visit to Harbor Freight; they are 24 inches long, and very heavy duty.
http://www.harborfreight.com/24-inch...ron-93230.html
You can't beat the current price of $5.99 for these tire irons. However, I think the Motion Pro tire spoons are much easier to use, and work very well for changing dual sport tires.
Old 05-28-2010, 08:45 AM   #13
Cal25   Cal25 is offline
I dont do tire changes very often but I have 2 spoons I have used for over 30 years. 1 is similar to the Harbor freight item in Spud's link only it's about 18 inches long. The other spoon is more flatter in shape and only 10 or12 inches long. I use the little one to hold the progress the big one makes.
Old 05-28-2010, 09:04 AM   #14
BamaRat   BamaRat is offline
I recently changed the tires out on my Zong. I was still unsure if I was going to do it myself so I just ordered 3 of these
http://www.rockymountainatvmc.com/pr...dFamilyId=3153
I was amazed with them. For $3 bucks a piece. They worked great and although I had never done a tire change before I finished it with no problem.
Old 05-28-2010, 09:09 AM   #15
Jim   Jim is offline
Those look like a really good deal thanks for posting
"Be excellent to each other"
